brake caliper paint
Old Jun 22, 2014 | 06:44 PM
cali760's Avatar
brake caliper paint
want to paint my brake calipers red. is there prepping and or special paint for calipers? has anyone done this? pics?
Old Jun 22, 2014 | 07:05 PM
justmaxxin's Avatar
Just go buy caliper paint at auto zone.Personally what I do is I remove the brake pads, caliper and detach the caliper bracket off spindle (don't disconnect brake lines) also I don't know how the brake slide pins are on the Max but cover those too and make sure you clean and put some anti-seize on them. Brush off everything your painting, tape and use plastic or newspaper for over spray on anything you don't want and paint on. Also don't worry about getting paint on rotors, it will come off when braking except for the hub area. Paint your rotors too! I hate when rust gets on the hub.
Old Jun 22, 2014 | 07:07 PM
justmaxxin's Avatar
Do this only if you know how to change brakes.. otherwise if not, I don't really know what to do then but have them done by someone that knows how.
Old Jun 22, 2014 | 07:16 PM
Mike11SV's Avatar
I used the G2 brush kit, in black. I took the wheels off, and carefully used the brush to paint the calipers. I like the ease of the brush, much easier to control (no overspray).
Old Jun 23, 2014 | 03:40 AM
Tommy6905's Avatar
Not sure year max you have, but I have the 2010 with red tails and the vht red caliper paint matched real well
Old Jun 23, 2014 | 04:56 AM
Ross2893's Avatar
Clean it the caliper by either washing it or using brake cleaner, then sand it with 320 grit sandpaper and then paint it. Quite frankly any paint will do because your calipers don't get that hot except for the bed in process. You can get engine enamel paint from walmart rated at 500 degrees for like $5 and that will be good enough for any job on your brakes
Old Jun 23, 2014 | 06:26 AM
justmaxxin's Avatar
id thunk the brake dust would screw up a paint that cant take that heat
Old Jun 23, 2014 | 07:57 AM
Mike11SV's Avatar
I have a brand new box of the RED G2 caliper paint kit if you're interested.
Old Jun 23, 2014 | 08:05 AM
Ross2893's Avatar
@Justmaxxin, how would brake dust really get on the calipers? And except when you bed in your brakes your calipers do not get that hot. Trust me, as we speak my rotors are very hot to the touch but the calipers are warm/cool and I just drove to work which is a 40 mile commute.
I just changed my rotors and brakes and painted my calipers silver and black. I used caliper paint but it's honestly an upsell to get "caliper paint."
Brake dust should be the least of your worries in regards to the part of the caliper that will be seen.
Old Jun 23, 2014 | 09:42 AM
VVhite-0ut's Avatar
Probably the easiest 20 bucks i've spent on my Max so far. Quick clean, scrub, mask, and paint! Did it in a few hours and man I couldn't be happier. Use the paint brush instead of the spray and you'll have no problems. Enjoy!
Old Jun 23, 2014 | 09:52 AM
cali760's Avatar
how much?
Old Jun 23, 2014 | 12:47 PM
Mike11SV's Avatar
$30 Shipped for it.
Old Jun 23, 2014 | 06:57 PM
cali760's Avatar
$30 Shipped for it.
check ur msgs
Old Jul 7, 2014 | 11:18 AM
cali760's Avatar
mike 11 u there. bub? i want that paint
Old Jul 7, 2014 | 11:43 AM
VVhite-0ut's Avatar
Not trying to stop a potential purchase/sale... but if you're having a hard time reaching him I'm sure you can pick up the caliper kit at any advance or auto store for $20 bucks. That's where and how much I got mine for... just a thought.
Old Jul 7, 2014 | 12:39 PM
VIP_MAXIMA's Avatar
Sooooo. No one cares to show any pictures? lmao
Old Jul 7, 2014 | 12:52 PM
Ghozt's Avatar
the caliper paint at autozone sucks. get G2 caliper paint, its an enamel and holds up much better over time.
Old Jul 7, 2014 | 06:51 PM
dr_2010SV's Avatar
^ Yes, G2 is a two part paint system well worth the few extra $$
Old Jul 9, 2014 | 09:02 PM
elevit's Avatar
Can caliper paint be used for painting rusting rotor hats as well? Thanks.
Old Jul 10, 2014 | 04:51 AM
dr_2010SV's Avatar
Yes. A few members here including myself have done so. Remember to prep the surfaces well for best results.
Old Jul 11, 2014 | 12:28 PM
elevit's Avatar
Thank you very much for the confirmation dr_2010SV!
Old Jul 11, 2014 | 08:16 PM
dr_2010SV's Avatar
Thanks,
Think about matching the caliper color to the rotor hats!
Something I wasn't thinking about when I did the calipers.
The rust on the hats didn't garner my attention at the time because it wasn't that bad.
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
