The Retrofit Source
Old Aug 1, 2014 | 06:40 AM
VIP_MAXIMA's Avatar
The Retrofit Source
I recently purchased LED lights blubs for my fogs and decided to grab a Morimoto kit from TRS. Needless to say, these lights are bright as hell. The best kit on the market hands down. Now the issue now is, these out shine my OEM HID head lights. Question is, are their any 6k REPLACEMENT bulb set that will work with the oem ballasts. (TRS wasn't sure if their D2S bulbs would work property as a replacement).
Old Aug 1, 2014 | 07:01 AM
I buy from them on the regular. Loveeee their products and they are the best that aftermarket has to offer.
Here's what I recommend. Enjoy!
http://www.theretrofitsource.com/com...d2s-bulbs.html
Old Aug 1, 2014 | 07:06 AM
VIP_MAXIMA's Avatar
I was looking at these.
Old Aug 1, 2014 | 07:11 AM
Even the 3Five bulbs should be fine but the XB35s are better and worth the extra money IMHO.
Old Aug 1, 2014 | 07:14 AM
VIP_MAXIMA's Avatar
Im glad i read the description at the bottom
What's Included
  • Bulbs:Morimoto XB35 D2S (Pair)Misc:Alcohol pads (to clean bulbs before use)Warranty:Two Years
Technical
  • Lamp Size: D2S
  • Lifetime (Hours): 2500
  • Wattage: 35
  • Rated Lifetime:2500 hours (5-8 years)4300KWarm White (3200 Lumens)5000KPure White (3050 Lumens)6000KTinge of Blue (2900 Lumens)
Compatibility
  • Headlights D2S Only; Not for use with OEM Nissan/Infiniti ballasts (Matsu****a)Cross-CompatibilityOsram: 66040 / 66240Philips:85122 / 85122+ / 85122C1 / 85122WXBMW: 63 21 7 160 806 / 63217160806Audi:N 104 457 01 / N10445701Lexus:909812002Mercedes-Benz:910139-000001 / 910139000001Not Sure?Find my size!
Old Aug 1, 2014 | 07:17 AM
VIP_MAXIMA's Avatar
Charlie @ TRS
Hi, how can we help you today?
You - Click here to change
I am trying to replace my D2S hid bulbs for my nissan
I see the XB35 is not compatable
Charlie @ TRS
Yeah exactly, you would want to use either the Philips or Osram OEM brands
Aftermarket bulbs will not reliably function with that ballast
Old Aug 1, 2014 | 07:27 AM
VIP_MAXIMA's Avatar
Charlie @ TRS
What kind of vehicle do you have?
2011 Nissan Maxima SV
Charlie @ TRS
Are your headlights halogen or HID factory?
HID
Osram or Philips
Which is the best bulb (brightness
6k
Charlie @ TRS
Either the Osram Nightbreakers or CBI's, depending on what color you want
Ah ok, so the CBI's are about 5500k
and the Nightbreakers are 4200k
Old Aug 1, 2014 | 07:29 AM
VIP_MAXIMA's Avatar
Is it true you guys will have a new d2s style bulb releasing soon
that is compatable with nissan/infiniti
Charlie @ TRS
We have these http://www.theretrofitsource.com/com...l#.U9uj3vldX78 but you said you wanted brighter ones
We are hoping so!
Old Aug 1, 2014 | 09:14 AM
XB35s are fine as are 3Fives. Others will chime in and agree.
I wouldn't recommend something that won't work.
Old Aug 1, 2014 | 09:33 AM
VIP_MAXIMA's Avatar
I ended up buying the Phillips 6k Replacement bulbs
Old Aug 1, 2014 | 10:27 AM
Ghozt's Avatar
yea the cheaper TRS bulbs dont work with the Matsu****a OEM Ballasts well, i dont get those bulbs anymore for OEM ballasts I either go all out with the Osrams or use a different source
Old Aug 1, 2014 | 04:41 PM
Old Aug 2, 2014 | 04:36 AM
Ghozt's Avatar
the threeFIVE's work on my 09, but my buddy's 2014 they don't come on all the time so he exchanged them. a bunch of the 7th gens in our Max FB group confirmed the same, they had issues too. theres a reason they say on their site it doesnt work with all Nissan/Infiniti.. the 09 and 14 ballasts have different part numbers so they must have changed something
Old Aug 2, 2014 | 05:55 AM
BIGIRISHSTL's Avatar
So I have a 2010 and have the same problem since putting 6k fogs on my car. Is the ballast the same as the 2009 on the 2010? Was looking at matching to the soft tinge blue of 6k as my fogs.
Old Aug 2, 2014 | 04:28 PM
Ghozt's Avatar
well fogs shouldnt be related. if you added aftermarket fogs, id recommend a relay kit if you didnt use one. that way they pull power from the battery when igniting the bulb and dont rely on the OEM wires, which in most cases weren't designed to handle that.
not sure if the ballasts are the same for those years. i cant tell if its just random Matsu****a ballasts that dont work as TRS indicates, or if its a specific revision of them that dont. but my client had an issue with them igniting every time and it got old quick, they have had 0 issues with their Osrams
Old Aug 2, 2014 | 06:36 PM
dr_2010SV's Avatar
Thanks Dan, I agree as it also took me a bit more inquiring with TRS to come to the same realization. It would be better if they (TRS) could indicate the actual applicability in regards to each year of the 7th gens.
Old Aug 3, 2014 | 12:04 PM
maximase86's Avatar
I love lamp.
For the foglight issue, you definitely should do use a relay. However, I've also had problems with the latest Morimoto ballasts even on a relay not firing when you turn the lights on multiple cars. So far I just deal with the issue, but probably should reach out to them.
For the OP, where on the TRS site did you find the LEDs? I see the Morimoto LED foglights, but not bulbs. Got any pictures?
S
Old Aug 5, 2014 | 08:37 PM
Jmaxx11's Avatar
Hid fog lights
What kit should I get for my fog lights and is it plug and play
aw11power
Oct 10, 2021 04:57 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
conansriver
Sep 11, 2015 10:26 AM
Hdnseek
Sep 9, 2015 05:55 AM
