2012 cvt trans noise at speeds of 80 Miles an hour
Old Oct 11, 2014 | 10:58 PM
maxima 2012's Avatar
7th generation Maxima a noise at speeds of 80 Miles an hour do you have the same noise' Curious what it is? it goes away when i go back to 60 mil, // sound like a whining noise // IS THAT NORMAL FOR CVT TRANS
Old Oct 12, 2014 | 03:56 AM
ThinBlue82's Avatar
It's the sound of your cvt transmission screaming for HELP! On a serious note, when the cvt heats up due to driving behavior and external temperatures the cvt will begin to whine and at times limit power by going into limp mode. I'd suggest slowing downing some and go easy on your cvt until you check your fluid level and condition.
Old Oct 12, 2014 | 09:22 AM
CorollaULEV's Avatar
1st step - check your transmission fluid. STAT! Don't wait - do it now. It should be a very very light tan color and should not smell or look burnt.
If either of these conditions are true - change it immediately and drive her REAL easy to go to the dealership or garage.
Second - with 120,000 miles on my 2010, I can tell you for CERTAIN that driving 80mph (or 90mph) won't cause this kind of noise from this transmission. Going 80mph isn't exactly easy on the transmission, but it does NOT cause heat buildup in the transmission. The transmission cooler on these cars is more than capable of cooling the transmission at freeway speeds.
Late,
Trav
Old Oct 12, 2014 | 04:04 PM
GNCMaxima's Avatar
Late,
Trav
Drive the car for 15 to 20 minutes (with the car still running) check for the fuild
Old Oct 12, 2014 | 08:33 PM
I checked the fuild IT IS GOOD
Old Oct 13, 2014 | 01:25 PM
Maximam's Avatar
The only time you should hear a whine from your tranny is when under heavy throttle. If you are cruising and hear your tranny you have trouble.
Old Oct 23, 2014 | 08:55 PM
noise at speed of 80 m
more like a grilling noise
CorollaULEV
30
Aug 9, 2021 08:11 PM
vingodine
45
May 21, 2016 12:46 PM
Maxgig
Aug 18, 2015 09:17 PM
yat70458
Aug 3, 2015 01:16 PM
