My e break light goes on.
Old Nov 17, 2014 | 10:13 PM
Mwolfram's Avatar
After school I was driving home and then i look down to see how fast I was going and my ebreak light goes on and so does my vdc light and showed my car was sliding. I also have this problem when i go home at night and leave my car in the garage for the night. I get in it in the morning and my breaks are hard as a rock! Its like i turn it off that night, pumped the breaks and left it. Please help!
Old Nov 18, 2014 | 12:55 AM
lightonthehill's Avatar
Those two warning lights are also used to warn of low brake fluid. The first thing I would check is the brake fluid reservoir just above the steering column in the engine compartment. Make sure the brake fluid is at the 'full' mark.
Old Nov 18, 2014 | 06:27 AM
Nitehawk11sv's Avatar
And do this quickly, if not, the carwill lock itself down and you will have absolutely no power like i did and it wont be safe on the road because it just wont go. Add some brake fluid and check the reservior like Light said above.
Old Nov 18, 2014 | 10:01 AM
ThinBlue82's Avatar
Additionally, if the fluid is low then you either have a leak or more likely your brake pads are worn and its time for a brake job
Old Nov 18, 2014 | 03:10 PM
Mwolfram's Avatar
Yeah I do know i need pads but i also got rotors. I just bought some stillen break pads and rotors for 521 shipped also wire break lines. It was a steal cause online they were 1100 im glad i talked to a rep. But what break fluid would be good?
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
lowpost99
Sep 8, 2015 05:06 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
