Anyone having problems with heated seats?
Old Feb 24, 2015 | 12:00 PM
eisenherz's Avatar
Hello, i have 2011 max sv, my driver heated seat dosent go on high anymore just low setting seems to work, ive only had the car a few days, is that an easy fix or i should bring into the dealership?
Old Feb 24, 2015 | 01:04 PM
Nopike's Avatar
It's not an easy fix unless you know how to remove a seat from the car. You need to go to the dealer, let us know how it turns out.
https://maxima.org/forums/search.php?searchid=3403562
Old Feb 24, 2015 | 01:11 PM
eisenherz's Avatar
ill call my dealer get you updated on what they did
Old Feb 24, 2015 | 03:45 PM
eisenherz's Avatar
strange enough, the high worked tonight, maybe its because this morning it was -35 with wind chill. Could have been some condensation that froze and made the connection impossible. ill keep an eye on it for sure.
Old Feb 24, 2015 | 06:18 PM
Nopike's Avatar
Do you have the heated/cooled driver seat with 3 heat settings and 3 cool settings? If not then it could just be a bad switch.
If you have the heated/cooled seat. If the seat bottom and seat back do not heat evenly the seat will shut off. The seats are designed to operate that way. This is more likely to happen when it is very cold. Once you have warmer weather the problem will probably go away.
Old Feb 25, 2015 | 11:08 AM
j_dubb's Avatar
I'd recommend calling the dealership and getting it documented all the same.
Old Feb 25, 2015 | 02:55 PM
maximase86's Avatar
I love lamp.
Sounds from the description he has just the standard heated seats. The fact that it works fine in low eliminates the heating elements from the equation. I'm not sure if the driver and passenger switch harness are the same. If they are, you could swap the switches and see if the issue still exists, or moves to the passenger seat. If it moves, then it's the switch.
S
Mar 12, 2020 12:06 AM
GregL65
Jan 17, 2020 08:01 PM
captchaos
Mar 15, 2016 12:18 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
GregL65
Sep 5, 2015 09:37 PM
