Frequent CEL P0101 - Service Bulletin
Old Feb 25, 2015 | 02:23 PM
maximase86's Avatar
I love lamp.
Hey guys,
Since I got my car (2011 SV-Premium), I've dealt with getting a P0101 MAF a few times. Back in December when the CEL came on, I took it in and the MAF sensor was replaced under warranty. Over the last weekend the CEL returned, and guess what P0101 appeared again.
I got the car in today and apparently there is a service bulletin out for it.
According to the invoice:
Reprogrammed the ECM as per NTB12-051j.
Perform IAVL Procedure. Erased all DTC's. Test Drove.
I did a search on the forum for the NTB I was given and didn't see anything. So here is a post about it just in case you are having frequent occurrence of the code P0101.
S
Old Feb 25, 2015 | 04:31 PM
1996blackmax's Avatar
Thanks for the heads-up!
Old Feb 26, 2015 | 05:48 PM
sonomamax's Avatar
I cant find it right now. but several months ago i was getting that code and had it cleared a couple of times by ORielley's. Then decided to get it checked, The dealer told me that there was a bulletin that covered that. They reprogrammed the ECM and it went away and never come back.
Old Mar 20, 2015 | 07:50 PM
Carguy0312's Avatar
I've replaced my sensor twice. Thanks for the info.!
Old May 16, 2015 | 09:59 AM
GNCMaxima's Avatar
Hey guys,
S
Did your car run faster/smoother after this? Im getting this done at 58k on my 12' just curious if this fixed the issue
Old May 26, 2015 | 07:05 PM
maximase86's Avatar
I love lamp.
The car didn't seem to run any more different then it did before after the ECU reprogram. Nor would I expect really much of a change other than not getting frequent CEL's. Been a solid 3 months and have not seen a CEL. *knocks on wood*
S
Old May 28, 2015 | 12:25 PM
dr_2010SV's Avatar
Same thing with my 2010. I cleared it by pulling the neg battery cable for 10 min.
CEL hasn't returned, been about a year now.
Old May 28, 2015 | 03:31 PM
GNCMaxima's Avatar
After 2 weeks the light came back on........ Fml
Old May 28, 2015 | 03:41 PM
Richard66's Avatar
You would think if there was anything wrong with the MAF then the light would come on a lot quicker than taking two weeks. I would look elsewhere for the cause.
Old May 29, 2015 | 06:37 PM
sonomamax's Avatar
Like a couple guys said.. You get the light... Why change a 400 usd sensor when the problem can be fixed free by the dealer. Takes them about 30 min or so. reprogram the ECM. problem solved... and it dont cost anything.. (at least mine didnt) a TSB covers it. Why take it to your buddy when the dealer already knows what and how to do it.. Just my personal opinion.
Old May 30, 2015 | 11:04 AM
maximase86's Avatar
I love lamp.
Agreed. Sure you can clear codes, or replace the sensor. However the TSB is a known issue, and you should make sure that your issue isn't that first. If you have not had the TSB done, I recommend you don't clear the code before going to the dealer to deal with it. Else they will say nothing is wrong and the repro may not come back for a little while.
S
Old May 30, 2015 | 05:53 PM
GNCMaxima's Avatar
Took it back today and they said they cleared the code. I don't think this is the right way to fix this problem. Car runs fine but if i have to take the car back every 2 weeks I give up lol plus its annoying! I cant stop thinking of what's wrong :/
Old May 31, 2015 | 09:03 AM
Nitehawk11sv's Avatar
With it being 105 degrees here now i was getting a cel for this quite often. I had to clean my K&N, take a look at how hot the intake was getting, and i got some MAF cleaner spray from autozone. Have not had an issue since.
Old Jun 10, 2015 | 02:01 PM
GNCMaxima's Avatar
In Texas it doesnt get as hot but still ive cleaned my intake every oil change and havent had this issue. Its just weird!
I forgot what the code actually spits out again. The guy from autozone said it but theres like 3 errors tied to that code.
Does anyone know what they are?
Old Apr 20, 2018 | 05:18 PM
thor2k's Avatar
ECM Reprogramming?
Can anyone point me to the reprogramming procedure as referenced in this post?
My 2012 is long out of warrant, with 180,000 miles, and my mechanic is stumped as why (BOTH) cat converter codes come on as well as the MAS.
I try to avoid the stealer as much as possible and want to know what we can do to narrow down the culprit(s)?
Thanks,
Jay
Hey guys,
S
my03maxima
Jul 28, 2024 07:40 AM
jmlee44
Oct 2, 2022 02:13 PM
RealityCheck
Oct 2, 2015 06:34 PM
MaxDD
Sep 24, 2015 06:40 AM
JoshG
51
Sep 21, 2015 10:41 PM
