Intermittnent problem with MAF. P0101
Old Mar 23, 2018 | 06:22 AM
ACDUBE1977's Avatar
I have a 2011 Nissan Maxima 3.5SV Stock as far as I know. I have codes P0101 & P0103. I have pulled the code from my own tester. MAF Sensor & High Voltage on circuit? I have changed my air filter and the MAF Doubled check the position of each and the tightness of the filter housing for leaks. The car is drivable, however certain moments Usually on idle it stalls out. I an start the car, but when I compress the gas its "STUMBLES" having no acceleration or power. I can pull over shut the car down and it seems to RESET the issue briefly or until I have to come off the accelerator. ( red light or in traffic). The vehicle runs decent on highway when in higher gears. I can feel lack of power however. But once I slow down and come down in gears or car is at idle...that's when it wants to "STUMBLE".
THANK YOU FOR ANY KNOWLEDGE OR EXPERIENCES. Trying to DIY rather than go to mechanic.
Tony
Old Mar 23, 2018 | 06:43 AM
Richard66's Avatar
https://www.autocodes.com/search
Go to this site and type in each code and it will give you detailed information on each code and possible solutions.
Old Mar 23, 2018 | 09:13 AM
Tremane2003's Avatar
For the p0101 there is a tsb for programming the Engine Control Module (ECM) I think I paid $150 at the dealership.
Old Mar 25, 2018 | 11:30 AM
dylantheblueone's Avatar
I went to the dealer, and I ended up paying nothing due to the TSB. They were originally going to charge the diag fee plus the $150.
Old Mar 27, 2018 | 06:11 AM
ACDUBE1977's Avatar
May I ask what is TSB?
Old Mar 27, 2018 | 07:14 AM
Richard66's Avatar
From Wikipedia
Technical Service Bulletins, or TSBs, are recommended procedures for repairing vehicles. They are a form of diagnosis. Not to be confused with recalls, a TSB is issued by a vehicle manufacturer when there are several occurrences of an unanticipated problem.
Old Mar 27, 2018 | 12:09 PM
ACDUBE1977's Avatar
Thank you.
Old Apr 12, 2018 | 08:32 AM
bball2100's Avatar
I just recently received the P0101 MAF sensor error code. I bought the MAF sensor cleaner and cleaned the sensor well, but the check engine light remained on. To further troubleshoot the problem, I took the air box and the air duct that connects the air box to the throttle body out of the car and cleaned/inspected it. I found that the air duct started to crack at each end where the connection clips are located. One of the cracks was to the point where it produced an opening for air to escape. From what I've read, this may be causing the error code, so I ordered a new air duct and am currently awaiting its arrival. If the check engine light doesn't go away, replacing the sensor will be my next step.
I'll continue to update.
Old Apr 23, 2018 | 08:38 AM
bball2100's Avatar
Update .. Received the air duct and replaced the old cracked one. A day later the check engine light turned off and has been off ever since. Gas mileage and power went back to normal, so I'm declaring this one to be fixed.
maximase86
Apr 20, 2018 05:18 PM
jyhan88
Sep 27, 2016 06:52 PM
jj9711
Jun 30, 2016 12:56 PM
mikekay
Jun 10, 2015 01:56 PM
Mlang2000
Aug 11, 2014 02:51 PM
