Dissconnecting the dash speakers?
Old Mar 28, 2015 | 06:59 AM
Bossman150's Avatar
Is there an easy way to do this? Do the dash speaker grills just pop off or is there more to it?
Old Mar 28, 2015 | 07:46 AM
Nopike's Avatar
Information is in here.
http://www.nicoclub.com/archives/nis...e-manuals.html
You have to remove the cover from the A pillar first then the grills will pop off. You will need to remove the two speaker hold down bolts to get at the connectors. Pretty easy with the right tools and some patience. Careful not to drop those bolts they can be a pain to get at.
Old Mar 28, 2015 | 11:07 PM
1996blackmax's Avatar
If you have it, the center channel grill just pops out. Slip something thin in between the dash & the cover & pry it out. Once you get it started, just pull it off. The opening here is a little smaller than with the left & right dash speakers. I made the opening slightly bigger by using a Dremel. This allowed me to install a Vifa 3.5" driver in there.
Old Mar 29, 2015 | 06:32 AM
Bossman150's Avatar
Thanks, I think I will try disconnecting all the dash speakers. If I had the Bose do I have the center channel?
Old Mar 29, 2015 | 07:40 AM
I believe so. The current Maxima specs say so. Don't know for sure if the older Maxima's were that way. I have navigation & DVD playback capability. Easiest way is to look under the grill if you have a center grill.
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
