Had the Eibach pro kit installed several weeks ago and finally got around the alignment. Love the way it turns, but the rear definitely felt twitchy on high speed bumps. Attached the alignment report, issue is with the rear camber adjustment (with the reat cams fully extended there is not enough camber.
I'm thinking there has to be a kit available to get this into adjustment, what are my options? Do the kits just utilize larger cams or are they more extensive?
I'm in unknown territory here
, any help / guidance will be greatly appreciated!
Thanks!
, any help / guidance will be greatly appreciated!Thanks!
Quote:
So this: http://www.ebay.com/itm/ICHIBA-REAR-CAMBER-TOE-BOLT-KIT-for-M35-M45-G35-G37-350Z-370Z-Z33-Z34-V36-Y50-/331172342372?hash=item4d1b68ea64&vxp=mtrOriginally Posted by MaximaDrvr
You need 350z arms.
This shows as NOT compatible with a 2011 Max. Also, other threads indicate that some of the adjustment threads need to be cut away (shortened). Was this your experience? thanks for the reply.
