engine thud
Old May 4, 2015 | 03:51 PM
jaydeezy's Avatar
engine thud
when i brake after going around 50mph the engine or the transmission i dont know which one slightly thuds and goes back to the normal idle...is this normal? it is very slight but definitely there...it will get stuck just above 1k rpm and then thud and then go under its not smooth
Old May 4, 2015 | 04:12 PM
chrome91's Avatar
so what exactly does the idle do when you brake? does it shoot up?
Old May 4, 2015 | 04:27 PM
jaydeezy's Avatar
it shoots up slightly...very minor though. I read further into this and some people are saying an engine knock when coming to an stop and it describes my situation perfectly. when i am coming to a stop the engine knocks
Old May 4, 2015 | 04:31 PM
chrome91's Avatar
so it feels like maybe weak engine or transmission mounts?
Old May 4, 2015 | 04:33 PM
jaydeezy's Avatar
mines is at 52k miles 2013 nissan maxima...would i be able to just take it to the nissan dealership and have them take a look at it?? it was a prior rental just got it a week ago from hertz
Old May 4, 2015 | 05:25 PM
Daaavid's Avatar
Doesn't sound normal. Check the transmission fluid. It may need to be changed. Dealer may charge you to take a look at it, but call and ask and provide them a VIN.
Old May 4, 2015 | 07:48 PM
1996blackmax's Avatar
Definitely not normal....as stated...it's worth getting it checked.
Old May 4, 2015 | 08:38 PM
chrome91's Avatar
as said i would let the dealer check it incase its trans related
Old May 4, 2015 | 11:35 PM
jaydeezy's Avatar
ok so after a few trips to a dealer and asking my friend i think its just me getting used the cvt...the rpm needs stays put around 1k rpm when i am coming to a stop and then drops to normal when i am completely stopped i dont know if that is normal or not but my friend says it is just the cvt
Old May 5, 2015 | 08:31 AM
mikekay's Avatar
I get a bit of a click (almost like the sound of a car doors locking from when you are onthe outside) around 40km/h on accelerate I was told there was a bit of a engine check that happens -- its a little annoying but you will get used to it,
Not sure if that is the same thud -- there is also a bit of an engine brake on the CVT's could the two be related?
Are you coming from a car that had a regular transmission?
Old May 5, 2015 | 10:30 AM
Lemonhawk's Avatar
When I first got my 2010 I recall a few times when stopped or just about stopped, the car would lurch as if I had been hit by the guy behind me. With some experimenting it appears that I was not pressing on the brake enough. With just a lite pressure on the petal the car would sometimes seem to "lurch" or"thud", just applying a little more pressure on the brake pedal eliminated the sudden thud or lurch.
Old May 5, 2015 | 03:35 PM
Daaavid's Avatar
The torque converter locks at 19 mph that you will feel when you come to a stop. Car does have engine braking in regular D and more aggressive engine braking in Ds mode, but it should not have an audible or heavy thump at 50 mph.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
