10 Maxima Motor mount Question
Old Jun 14, 2015 | 06:34 PM
Jcof88's Avatar
hey guys I have a question I have a 2010 maxima s and when I am braking I get a lot of vibration from the steering wheel and brake I replaced both wheel bearings and brake and rotors all the way around still I get this shaking. anyways after looking around I replaced the side motor mount and the front motor mount and its 100% better but still have some vibration. I am thinking I need to replace the back one but its to hard to get to. Also there is another side motor mount with hydraulic fluid in it is there a way to fill that back up and if so what fluid is it. Thanks for any help guys
Old Aug 20, 2015 | 06:50 AM
rtirbany's Avatar
motor mounts
hi,
I saw that you changed your motor mounts recently and am researching doing the same on my 2009 (right side, front, and right torque mount done)...
Just wondering - did you go w/ OEM or aftermarket? Any particular features to look for (inserts or other?)
Coming from a 97, my new ride is as smooth as silk (when not braking, shifting to/from park)...I'm hoping to have the same result and this is a concern w/
going aftermarket.
Old Aug 20, 2015 | 08:56 AM
mjhuffer's Avatar
I'm having the same vibration in my steering wheel while braking and I was hoping it was a problem with warped rotors. I'm going to replace all rotors and pads to see if it helps. How hard was it to replace the front and side motor mount? Did you do it yourself or did you have it done somewhere?
schmellyfart
Sep 25, 2015 04:47 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
