Fog lights won't turn on
Old Oct 25, 2015 | 02:10 PM
Khryzthyan's Avatar
I just install fog lights..my maxima came with wiring for them..after install I turned them on and instead the headlights turn on..please help!!
Old Oct 25, 2015 | 03:19 PM
Richard66's Avatar
Did you also install a new light stick on the steering column where there is a separate switch just for the fog lights?
Old Oct 25, 2015 | 05:29 PM
Khryzthyan's Avatar
The car came with the fog light switch on the light stick..well at least I think so..it has the off setting then auto then on then fog..I recently install HID kit on the car..could that had some thing to do with it?? I also checked the fuse for the fog lights it was good
Old Oct 25, 2015 | 07:03 PM
Richard66's Avatar
The light stick has two separate switches that rotate. The one on the end of the stick has four positions, Off, Auto, Parking, Headlight. The inner switch has two positions, Off and Fog.
That is the way the factory wires the switches up.
Old Oct 25, 2015 | 08:18 PM
njjfudge's Avatar
Sounds like you need the combination switch with the fog light switch on it or get a fog light wiring harness.
Old Oct 26, 2015 | 10:02 AM
Akiyukio's Avatar
Take a look at this thread: https://maxima.org/forums/7th-genera...y-s-model.html
It sounds like you do not have the correct switch installed. You only have the regular headlight stalk.
For reference, the switch positions are:
Off
Auto
Parking lights Only
All On
EuroDriver
Sep 14, 2015 06:08 PM
Dman1989
Aug 27, 2015 09:10 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
