new rims
Old Nov 5, 2015 | 06:00 PM
bobbybuttonz's Avatar
new rims
hi everyone im looking for help with my 2010 maxima i want to put 22 x 9.0 in the front and 22 x 10.5 in the rear Offset Front +38mm Rear +40mm tire size 245/30/22 and 275/25/22 i did run this setup on my 2004 infiniti g35 coupe and it was perfect can i do it on my 2010 nissan maxima sv
Old Nov 6, 2015 | 04:03 AM
lexcitement's Avatar
Rubbing Issues
You will have major rubbing issues unless you do some serious fender modifications. With 20's you could prolly get away with slight modifications. Good luck on whatever you decide to do though
Old Nov 6, 2015 | 09:06 AM
MaximaDrvr's Avatar
Front would be fine. Rears may be a problem.
Old Nov 6, 2015 | 09:23 AM
thanks for the info i see some people run a 295 tire in the rear i want to run a 275 i dont know how they do that with no mods the rims i want have a 40mm offset x10.5 it should be 1.75 inches closer to fender and 1inch to the strunt so it looks likei it will be flush with the fender im going to do it in the spring time does anyone have pics of there 8th gen max with 22s staggered setup and info on width and offset + tire size thanks again
Old Nov 6, 2015 | 04:44 PM
MaximaDrvr's Avatar
The problem is the 22s. You could run what you are looking at in 20s all day long. The 22 don't have a tire that will keep the same outer diameter.
I run 275 all the way around. The width isn't really the main issue. It it the width and overall diameter.
Old Nov 7, 2015 | 04:15 AM
2011maximapa's Avatar
Exactly right. 20s are big enough anyway. They look great on the car without sacrificing ride quality or performance too much if any. Probably not enough to notice unless you're either extremely picky or work for motor trend.
Mochedda
Dec 15, 2015 11:27 AM
ColdCananda
Sep 20, 2015 10:45 PM
Bernhard
Sep 14, 2015 12:49 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
Justin Kroll
Sep 2, 2015 11:06 AM
