Niche Invert rims
Old Dec 13, 2015 | 03:00 PM
MidnightMaxima_22's Avatar
Niche Invert rims
Just bought sum Niche rims Invert M162 I just wanted to ask what is the best way of getting them mounted the right way with no rub tire size and do I need spacers?
Old Dec 13, 2015 | 04:02 PM
These are the rims ijust got
Old Dec 13, 2015 | 04:27 PM
MaximaDrvr's Avatar
You need to tell us the wheel specs. We are not psychic.
Width. Offset. Diameter.
Old Dec 14, 2015 | 11:23 AM
Maximam's Avatar
Originally Posted by maximadrvr
you need to tell us the wheel specs. We are not psychic.
+1......
Old Dec 14, 2015 | 03:41 PM
My bad
They are 20x9 +25 offset
Old Dec 14, 2015 | 05:38 PM
Maximam's Avatar
Originally Posted by MidnightMaxima_22
My bad
Should be OK with a 245/35 tire. No spacer.
Old Dec 15, 2015 | 09:26 AM
MaximaDrvr's Avatar
Originally Posted by maximam
should be ok with a 245/35 tire. No spacer.
+1
Old Dec 16, 2015 | 10:42 PM
If I were to put spacers what's the best size?
Old Dec 17, 2015 | 10:49 AM
Maximam's Avatar
Why would you do that? Is your goal to rub?
Old Dec 17, 2015 | 10:55 AM
MaximaDrvr's Avatar
They won't fit with spacers.
Old Dec 18, 2015 | 10:00 AM
The place where I buy my tires they dnt have the 245 I want but they told me that the 255 is optional does it affect the ride quality?
Old Dec 18, 2015 | 10:16 AM
Asav's Avatar
I would go with the tires these guys told you to get. That 10mm might make all the difference since you are +25 on that 9 inch rim.
Old Dec 18, 2015 | 11:30 AM
Maximam's Avatar
A 255 has a larger overall diameter and width than the stock size which will increase your chances of rubbing both on the fender edge and the inner fender liners when turning. Putting a 245 on a 9" rim already widens the tire plus you are running a 25mm offset which puts it further out.
Find a tire shop that will sell you the proper tire size, not the size they have and are trying to get you to buy.
Old Dec 18, 2015 | 11:41 AM
Thank you sir
I already told them I want the 245 so they have to order the tires
Old Feb 19, 2016 | 08:21 PM
Before!
After!
Maxima50
Jan 21, 2016 03:25 PM
k2a2b
Dec 11, 2015 06:24 PM
nissanmaxgirl7777
Dec 8, 2015 11:54 PM
DDLam
Wheels/Tires
Dec 1, 2015 10:48 PM
