Oil change
Old Jul 11, 2016 | 03:01 PM
Reza2016's Avatar
Oil change
Does anybody recommend the synthetic oil for Maxima 2013? I used a conventional one and wanted to know if it is OK? Also for the gas if the premium is recommended?
Old Jul 11, 2016 | 04:59 PM
Richard66's Avatar
Page 9-3 of the owners manual.
FUEL RECOMMENDATION NISSAN recommends the use of unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (Research octane number 96). If unleaded premium gasoline is not available, you may use unleaded regular gasoline with an octane rating of at least 87 AKI number (Research octane number 91), but you may notice a decrease in performance.
As to synthetic oil, I have been using it for decades on all my vehicles. I have an 09 SV sport and the first oil change after dealer freebies ran out a couple of years ago, I switched to full synthetic. Just a better formulation for engine oil.
Old Jul 11, 2016 | 06:04 PM
14blackbeauty's Avatar
maximum performance put in the good stuff on gas and as far as oil you just can not go wrong with synthetic!
Old Jul 12, 2016 | 07:53 AM
Reza2016's Avatar
Thanks for the explanation.
Old Jul 12, 2016 | 12:08 PM
dmcmahan12's Avatar
I had good luck with Castrol Syntec Edge that I ran in my 400HP Subaru STI. When my free oil changes go away I will run it in the Maxiama.
Old Jul 12, 2016 | 07:34 PM
glockedc's Avatar
So regular unleaded just takes away performance? I always heard it was really detrimental in these engines.
Old Jul 12, 2016 | 09:33 PM
Richard66's Avatar
The way I see it, the Maxima is designed to run on 91 octane. Anything less is a hindrance to efficiency, which is detrimental to the operation of the engine.
Old Jul 12, 2016 | 09:40 PM
240tomax's Avatar
The way I see it, the Maxima is designed to run on 91 octane. Anything less is a hindrance, which is detrimental to the operation of the engine.
Really don't want to get this started, but........ based on what science.
Old Jul 13, 2016 | 02:52 AM
Fakie J Farkerton's Avatar
High compression engines should always use high octane gas
Good read:
http://www.economist.com/blogs/babba...octane-ratings
And Amsoil synthetic FTW
Old Jul 13, 2016 | 07:59 AM
240tomax's Avatar
Good read:
Great article with a great explanation. However, even the author isn't sure of the results of using regular fuel in vehicle where premium is recommended..... "no one has been able to tell him what damage is done, if any, by running the engine permanently in a retarded state, and forcing the anti-knock system to remain active all the time." I would like to see research on this.
Old Jul 13, 2016 | 12:09 PM
1996blackmax's Avatar
The higher octane gasoline is recommended for peak performance on the Maxima.
On my GLI, VW states that the power & torque specifications were attained with premium fuel. You can use regular, but performance levels will drop.
As for hurting the engine...I never really got into that. Why get a car knowing it recommends premium gas if that's not the person's intention? I just always use what the manufacturer recommends.
Old Jul 13, 2016 | 06:51 PM
you bought a premium car give it premium fuel! Save now pay later, just my 2cents! Will it hurt the car, Who knows but IF it does you will kick your self for it later
Old Jul 13, 2016 | 09:34 PM
Not another gas thread....
Regarding your oil question, there are only 123,456 threads on this subject here. Not to mention the internet.
reallywildstuff
18
Oct 29, 2019 10:09 PM
valerit1
May 19, 2016 04:13 PM
stellings
Nov 5, 2001 03:32 PM
RussMaxManiac
Sep 6, 2000 06:13 AM
yongjun
Aug 23, 2000 09:42 AM
