Racingline Y-Pipe Install
Thank you MaximaDrvr.....got the Racingline Y-Pipe you sent and installed it today and, fit perfect...I think the car idles smoother, slightly deeper exhaust note and little more raspy when you get on it. Great investment. I was in the "modding mode" today so also removed the coolant lines from the Throttle Body. I used the forward longer hose, removed the rear shorter hose, and connected the front hose in it's place....simple 15min change. I live in Phoenix so no danger of "icing" on the throttle body. This should supply slightly cooler air to the engine.
