After market spoiler - how to wire to third brake light or brakes
Old Oct 11, 2017 | 05:13 PM
shawn1274's Avatar
Hi guys,
new to to this forum. I have 2014 Nissan Maxima SV, I just installed after market spoiler, physical spoiler install looks good. But I am unsure how to connect the LED brake light. It comes with a red/black cable, but since I don’t have a harness or nothing apparent to connect it to. Does any one know how to connect it to the third brake light or brakes? There does not appear to be a harness or anything to connect the two light to. Any advice would be greatly appreciated.
Old Oct 11, 2017 | 05:14 PM
shawn1274's Avatar
Or can someone identifies what the third brake wiring looks like, if car did not come with spoiler. Everything under the panel seems to have a connection.
Old Oct 11, 2017 | 05:21 PM
shawn1274's Avatar
Pictures attached
Attached Thumbnails After market spoiler - how to wire to third brake light or brakes-190a17bf-23e9-4763-8309-7295e2e5d767.jpeg   After market spoiler - how to wire to third brake light or brakes-78327520-c71a-43b5-b7ef-cb5649c99d07.jpeg   After market spoiler - how to wire to third brake light or brakes-b7ee96e8-36c7-475c-8e22-2728e4a3d186.jpeg
Old Oct 11, 2017 | 10:12 PM
GodFather's Avatar
Made in Taiwan
Use a voltmeter, tap the ground end (usually the black gator jaw) to the fattest wire, (the fat wire is usually ground wire). Then get someone to turn on car and step on the brake as you use the red wire of voltmeter and test each of the skinny wires to see which one has power. The wire which responds to braking will be your lead wire to tap for the red wire to your spoiler. Then tap the fat wire of brake light harness to the black wire of your spoiler and you are all done. Good luck buddy.
Old Oct 12, 2017 | 08:53 AM
shawn1274's Avatar
Thanks Godfather. I did not get your post until now. I previously had a tow hitch and connector installed. I tapped into the connector's brake and ground wire and it works perfect. Again, i appreciate the input.
Old Aug 30, 2020 | 11:38 PM
Robert White's Avatar
Where are Breaklight wires located and color on a 2014 nissan altima?
where are the spoiler breaklight wires located and colors? On my 2014 nissan altima.
