How to remove plastic around 2014 gear shifter
Old Apr 18, 2018 | 05:00 AM
Denise728's Avatar
Yes, I know I did something beyond dumb. A tiny hair clip slipped on black rubber in gear shifter selection. I tried to get it and went under plastic chrome plastic. I felt the shifter obstructed when I put in park.
Do I have to remove cup holder, **** and pin on gear shifter and all plastic to get underneath gear shifter?
Clearly, I will not attempt myself. But is that only way to get under gear shifter console?
I know, I should have put in drive w ebrake on, to have bigger space to retrieve.
Thank you; I feel bad enough- please no girl jokes. Thanks!
Old Apr 18, 2018 | 07:46 AM
ButtaMax's Avatar
http://www.nicoclub.com/FSM/Maxima/2009/IP.pdf
Just pry it up, CAREFULLY..
Love your pink screwdriver BTW. Vids on youtube as well.
Old Apr 18, 2018 | 08:27 AM
Denise728's Avatar
I checked out you tube and they removed coffee cup holder and all surrounding plastic; just to get to under gear shift assembly
Thanks- pink screwdriver is from ladies tool kit
Old May 3, 2018 | 10:49 AM
Nissanfinatic's Avatar
I did it the other day slde down the plastic ring at the base of the shifter pop the metal ring off and pull of the shifter
I used a small flat screwdriver to pop off the plastic it's easy.
ugufru
Nov 10, 2015 06:46 PM
Roosky
Sep 7, 2011 10:22 AM
ADHDmax
Nov 4, 2009 11:37 AM
RAZER
Aug 28, 2002 01:03 PM
nm
Jul 25, 2002 07:15 AM
