Still getting P2101 Code After Throttle Body Change
Old Jan 14, 2019 | 05:29 PM
10aCMike's Avatar
My trouble started on a very cold morning when my battery died. When I attempted to start the car there seemed to be just enough juice to activate some of the electrical system. The engine never attempted to turn over, but I could here what sounded like relays opening and closing in the engine fuse box, and the car was stuck doing this for about 5 minutes. I could not turn the ignition back to off, it was just stuck in this sequence. Eventually I was able to get the ignition switch back to off and stop what ever was going on electrically. I suspect some electrical components may have been harmed during this process but did not find any blown fuses. I do not know how to check relays.
I attempted to jump start the car, it would attempt to start but would not. A mobile mechanic that just finished replacing my axel, and assisting with starting the car sprayed gasoline into the intake to no avail. I bought a new battery, installed it and it still would not start. I bought a scanner, pulled the codes and got: P2101 and P2119. I figured the copious amount of gasoline sprayed into the intake may have mixed with carbon on the back side of the throttle body and mucked up the intake. I removed the throttle body and it was indeed mucked up from the fuel spray and carbon. I removed the throttle body and thoroughly cleaned it and the MAF sensor with the proper chemicals, and reinstalled. The car would then start but would only idle to 1K RPMS, and slightly jump above then back to 1K when the peddle was pressed. It would continue to run until turned off, but was otherwise unresponsive beyond the aforementioned. In addition it was still throwing the P2101 and P2119 codes. I tried the different reprograming methods to no avail.
I ordered a used throttle body, cleaned it, replaced the gasket and installed the second throttle body. Nothing changed, I'm getting the same response. I temporarily got a P0221 code, but now it's only throwing the P2101 code again. I don't know if the electrical system being stuck in limbo for about 5 minutes from the low battery killed some electrical components, if I happened to receive a bad used part, or if the mechanic spraying copious amounts of fuel into the intake washed muck down into the cylinder and messed something up.
Any insight appreciated!
Old Jan 14, 2019 | 06:26 PM
Les7311's Avatar
I read something on the previous generation, and had a similar problem with cleaning the TB. Had to get dealer to install a new TB and reprogram. Not supposed to manually open the butterfly on the TB.
Lesson learn, and this may need fix by dealer.
Whats the other code meaning?
Old Jan 14, 2019 | 06:28 PM
Les7311's Avatar
https://www.autocodes.com/p0221.html
https://www.obd-codes.com/p2101
read up on these two. Your fix maybe leading to dealership install and programming. Cost about $500
Old Jan 16, 2019 | 10:39 AM
10aCMike's Avatar
Whether the plates on an electronic throttle body can be moved is a highly debated issue between mechanics. For every one that says you can't are just as many that say you can, as long as it's done gently after power is removed (but reset procedure must be performed). Unfortunately sometimes the TB cannot be properly cleaned without moving the plates no matter how great the TB cleaner.In my case moving of the plates does not appear to be the issue. I had my mobile mechanic by yesterday and I seem to be having an electrical issue where the TB is not receiving the proper amount of voltage or signal to properly operate the plates. I fear as I mentioned in my original post that programming in the ECM or something else electrical was harmed when the electrical system attempted to turn on but didn't have enough juice from the battery and become stuck. I'm going to go ahead and have it diagnosed at the dealer instead of throwing parts at it. I've already bought another TB and gasket and that didn't fix the problem. Thank you for your input.
Old Jan 17, 2019 | 12:19 PM
10aCMike's Avatar
Update: Unfortunately I was correct about the electrial issue. I towed it to the dealer today and my ECM is shot. They want 1,600 to replace and reprogram a new ECM
So, I'm going to buy a used one and have them program it for $400, but first I'm going to check with the non-dealer Nissan specialist in the city to see if anyone else can program if for less.
Juggernautt
Nov 3, 2018 10:10 AM
TrueMaxima03
Jun 26, 2014 04:53 PM
SR20DEN
Aug 20, 2010 10:31 PM
Tomegun
Jan 1, 2006 03:09 PM
