cvt running hot
Old Feb 20, 2019 | 02:18 AM
bebekhijau's Avatar
cvt running hot
using cvtz50 apps from playstore, my cvt always running hot, normal operating temperature is at 212 F. it is a used car. Done cvt fluid flushing and trans oil cooler cleaning (with pressurized water).
So what could possibly wrong ?
I know that trans oil temp will be approximately same with engine coolant temp. Could this is the reason why my trans fluid so hot ? my engine temp gauge is normal though.... never pass half gauge
Old Feb 21, 2019 | 11:02 AM
mahanddeem's Avatar
212F is hot, normal is 122 to 170F. What is your CVT deterioration date?
Have you replaced CVT external filter? Any fluid leak? Coolant leak?
Edit: Could be low fluid level in CVT.
Old Feb 24, 2019 | 08:59 PM
bebekhijau's Avatar
i have reset the deterioration date after cvt fluid change two months ago.
No fluid or coolant leak .
CVT fluid also ok.
Let me replace CVT external filter first..
Old Feb 25, 2019 | 08:03 AM
Richard66's Avatar
So before you started chasing things down, first you actually verified that the 212 degree reading is correct and not a false reading?
Old Feb 26, 2019 | 06:26 AM
mahanddeem's Avatar
If his OBD adapter works fine, I doubt CVTz50 is malfunctioning. It is a well-built app that pulls many vital parameters from the TCM. I second investigating issues in cooling his CVT.
SuperBlack
Jun 17, 2023 02:02 AM
Legionnaire1856
Jan 28, 2019 10:12 AM
02nissmax
Feb 24, 2016 06:54 PM
CorollaULEV
21
Nov 8, 2012 06:57 PM
X07MaxX
Fluids and Lubricants
Aug 16, 2012 10:54 AM
