7th gen maxima check engine light does anyone know
Old Apr 11, 2019 | 11:44 AM
Jfaze401's Avatar
Old Apr 11, 2019 | 11:55 AM
mahanddeem's Avatar
Welcome to maxima.org
Please check stickies for common issues and opening new threads. This is not your average Facebook fan page.
These codes could be a magnitude of things, what is the car? Year? Mileage? Trim? Any symptoms or issues? Service engine soon light on?
Details needed for guidance.
Old Apr 11, 2019 | 03:22 PM
Bificus99's Avatar
Google has those codes. Can bus connectivity was one of them. Like Mahandeem asked what are the details?
Old Apr 12, 2019 | 02:15 PM
Jfaze401's Avatar
2010 nissan maxima s with 107 on dash I got it at 23 the check engine light comes on and off
Old Apr 12, 2019 | 03:55 PM
danalmsa's Avatar
I get P0725 and U1000 when every I re-flash my ECU with the UpRev ROM editor. I have no drive-ability issues and I don't actually get a light. If I clear it, it won't comeback until I reflash. For the heck of it (and what I would suggest) is to check your grounds. I did clean mine up on some spots (battery to Transmission) and added extra grounding, though I don't think this had much impact..
Old Apr 12, 2019 | 04:06 PM
mahanddeem's Avatar
How does UpRev serving you? Does it really "tweak" performance?
Old Apr 12, 2019 | 07:48 PM
Jfaze401's Avatar
I replaced the positive terminal and clean the negative terminal and turn on the car and everything was going no check engine light do you guys think will it come back it says online it's a speed sensor and what is a UpRev ROM editor
Old Apr 12, 2019 | 08:05 PM
Bificus99's Avatar
My bet is ground or power issue. Was it driving poorly?
Old Apr 12, 2019 | 08:07 PM
Jfaze401's Avatar
To be honest it's been sitting in the garage for almost 2 months that I took it out did a oil change and everything else to it butt. Positive terminal was corroded in my fuses was gone so I replaced everything today when I turned it on the engine light was still on drove it for a little bit just got in a right now and it's actually off but overall the car is running good
Old Apr 12, 2019 | 08:30 PM
mahanddeem's Avatar
Clear codes, drive, and enjoy.
If same codes come back soon, then have a deeper look (provided car is running fine and you have no drivability issues).
That's pretty much what I do with almost any CEL problem.
Old Apr 13, 2019 | 06:55 AM
Jfaze401's Avatar
Hey I went to nissan dealer and hold them about the check engine light that come on and off and they told me I have to get the computer update I never heard that before is that true I can do a computer update its about 150 they told me
Old Apr 13, 2019 | 02:14 PM
mahanddeem's Avatar
Probably they relate the U1000 code to faulty module communication. I'd do the ECU update, might not fix things but I don't see it cause additional problems, and if I remember correctly update also tweaks CVT RPM-shift points for 09 and 10 so if 150 is swallowable for you do it but let them know if you still get CEL they need to continue to troubleshoot things.
chillin014
Apr 13, 2005 05:33 AM
adam1020
May 7, 2003 10:27 AM
Bonustracks
Apr 26, 2003 08:40 AM
ShastaMcNasty
Apr 11, 2003 09:19 AM
montwalker2001
Mar 11, 2003 09:13 PM
