2010 max Front Sway Bar Bushings
Old Aug 13, 2019 | 02:57 AM
Ray Velez's Avatar
Unhappy 2010 max Front Sway Bar Bushings
how do install them ...bc i see no way to do it . has any one changed them b4 need help plz
Old Aug 13, 2019 | 03:11 PM
VeeQue35DE's Avatar
You'll want to go in from the top, there's no access from the bottom.
Old Aug 13, 2019 | 03:56 PM
Qawmuh's Avatar
Can you elaborate on what you mean on start from the top?
Old Aug 13, 2019 | 06:23 PM
MaximusN8's Avatar
I'm curious to know the process of this repair as well, I been under there several times and every time I go under and look at it I'm there looking all over for a way that this could be done. I've done this on other cars easily but this one looks like there's a specific way it has to be done.
Old Aug 13, 2019 | 07:07 PM
VeeQue35DE's Avatar
When you take the intake manifold off, you'll be able to access/move the rack, lines, mount, etc. Then remove the shackles to the stabilizer. I know you can't take it off from the bottom because of the large subframe. You still may have problems with space since the engine bay in this car isn't the best to work with...Good luck
Old Aug 13, 2019 | 08:47 PM
Ray Velez's Avatar
thanks friend... looks like is going to have be done by a shop
Old Jan 24, 2021 | 04:19 AM
Les7311's Avatar
Bump. Hope someone has a write up.
Old Jan 26, 2021 | 06:52 AM
Tmcttk's Avatar
Here's the other thread talking about the front sway bushings with a DIY how-to write-up. Front Sway Bar Bushings - Maxima Forums
Old Jan 26, 2021 | 08:52 AM
Les7311's Avatar
notice post about how to access bushings from above?
Tommy6905
Mar 26, 2015 11:52 AM
nyc_ink
Feb 26, 2012 08:45 AM
maximagxe90
Feb 25, 2004 05:48 AM
chris92
Aug 15, 2003 01:33 PM
mzmtg
Mar 23, 2001 06:42 AM
