sway bar bushing and end link bushing replacement
i searched and could not find a write up for these. can anyone help.
ps. for the members who swear your supposed to be born knowing these things
and say dumb shet trying to make themselfs look good cause they know how to
do it and i dont, can GFTO if there not gonna help.
Procedure:
ok so i bought moog for both of them.
i was looking under the car and i was thinking of just doing one bracket at a time
for the sway bar bushings. im afraid to take them both out then cant find a way to
put them back while trying to balance the bar.
Temporarily connect the sway bar with the end links to the LCA. I'm just not sure if you need to align the sway bar though.
Ok here is what I did on my maxi... I understand the 5th gen is bit different but the process is the same:
Moog is what used when I replaced mine and I very happy with my choice... they had grease fittings which will allow you grease the end links when needed... Also moog makes pretty good sway bar link bushings..
Then lift the front end of the car and secure with jack stands, don't just use the tire jack...
Remove both left and right side sway bar link ends, that will relieve the pressure from the actual sway bar...
then you will remove the brackets that hold the actual bushings on the sway bar... use a light coat of grease on the bushing when putting those into the brackets that actually hold them, then tight down that brackets with the bushings inside. Those bushings are open sliced so you will be able to open them and slide them over the sway bar link
last step will be to add the end bushings on each side...
Just remember do not over tight the bolts on either the bushing brackets or the sway bar links...
Enjoy your free clunking ride... if that was your problem...
kingw323
20
Oct 21, 2015 08:36 AM
MaxStock
Aug 14, 2015 10:03 PM
