Anyone using 245/45/19 instead of 245/40/19 tires on their 7th Gen?
Old Feb 17, 2020 | 03:45 PM
Nopike's Avatar
I'm considering installing 245/45/19 instead of 245/40/19 tires on my 2014 sport. Anyone gone with the higher aspect ration, 45, tire? Any issues with clearance? Any issues that you noticed with handling? Does it look any different? I feel like the extra height may actually help when I inadvertently hit an unexpected pothole.
I don't consider my Maxima to be a high performance vehicle so I don't feel like I need high performance tires, brakes and so on. It just looks good and gets me around town comfortably.
Old Feb 18, 2020 | 02:41 PM
mahanddeem's Avatar
Might not look right, and will slightly off your speedometer.
Maybe non-sport S wheels and 18s?
Old Feb 18, 2020 | 04:36 PM
Nopike's Avatar
The car will only sit 1/2 inch higher so I doubt anyone would even notice. Speedometer would be 1-3 miles off, I can live with that. 19" wheels are fine and look good no reason to replace them.
Old Feb 18, 2020 | 04:47 PM
mahanddeem's Avatar
Seems like you made up your mind, why bother asking then?
Edit: It will look "Altim'ish"
Old Feb 18, 2020 | 04:52 PM
LtLeary's Avatar
Please let us know how it fits and rides if you pull the trigger. I have to admit I a a bit curious.
Old Feb 18, 2020 | 05:46 PM
Nopike's Avatar
I don't expect any issues but am hoping to hear from someone that has actually done it. I'm more concerned about clearance of front struts than anything else. Have not decided anything yet.
Old Feb 21, 2020 | 06:07 PM
AndyG's Avatar
Hi, I did it for the same reason as you are saying. It rides a lot smoother and I think you will be happy. Yes it's about a 1/2" taller, but no issues as far as fit. I bought the car to have a 4 door sedan, but I will admit I really like the sport package and the 19" wheels look great (2014SV). I don't really consider it a sports car either, so that's why I went for the smoother ride. If I want to jam, I just drive the sports car (911).
Old Feb 21, 2020 | 07:15 PM
Nopike's Avatar
Thanks. Do you really notice the difference in height when you look at the car? Is the difference in ride/cornering even noticeable?
Old Feb 22, 2020 | 07:08 AM
AndyG's Avatar
You can see the difference in height when you look close, but it doesn't look out of place at all. I feel the 40 tires really help if you are cornering hard and I just don't do that with this car. It definitely rides smoother and that's what I wanted.
Old Mar 13, 2020 | 02:05 PM
Litldevlmike's Avatar
My buddy gave me a set of 245/45/19 I installed them on the original rims no issues at all the only thing it just doesnt look right to be honest the low profile is alot better looks but performance wise they great kinda helps with the pot holes around the city so it doesnt Bend the rims
Old Mar 13, 2020 | 06:51 PM
Nopike's Avatar
Thanks for posting. I'll keep that in mind. I probably won 't get new tires until the fall so I have plenty of time to decide.
Old Jun 11, 2022 | 07:14 PM
Max2011sv's Avatar
Could you please share pics of your car with the 245/45/19? I’m thinking of doing the same. Will it interfere with the wheel well if I have myself and 4 adults sitting in car with me? In terms of car going low with weight?
Old Jun 11, 2022 | 07:18 PM
Max2011sv's Avatar
Did you go ahead with the 245/45/19 .. ? Can you share pics please? If I have myself, and 4 other adults in the car, will it affect the space in tire wells? Like, will car go lower and hit the wells if weight is added?
Old Jun 11, 2022 | 07:28 PM
Nopike's Avatar
No, I stuck with the 245/40/19. Although I wish I had the 45's when I hit that pothole and dented my wheel a couple of months ago. I can't say for sure but I would not have any issues with putting the slightly larger aspect ratio tire on the Maxima. I don't think there would be any problems with doing so. It may change the handling a bit but I doubt anyone would really notice. You might consider asking the local tire shops what they think.
Old Jun 11, 2022 | 07:36 PM
Max2011sv's Avatar
thanks! I checked with a couple and they said ask your dealership and do what they say. Dealership says either go down to 18 rims and get 245/45/18 or keep 245/40/19.
Old Jun 11, 2022 | 07:50 PM
Nopike's Avatar
Smile
Personally I would not take anything the dealership says too seriously. I have had lots of weight in the trunk of my car. Like many bags of topsoil or cement pavers and the rear sat very low without issues. Maybe in worst case you may get some bottoming but you would probably have to fill the car with 300lb people.. I'm not sure what that is in Kilos. Many 7th Gen owners lower their cars without issue. Personally I did not even consider that the wheel hitting the well would even be an issue. The difference in height between the two wheels is an inch. https://tiresize.com/calculator/
Old Jun 11, 2022 | 07:52 PM
Nopike's Avatar
You damn Canadians and your metric system
Old Jul 8, 2022 | 01:28 PM
PUPPET16's Avatar
245/45/19 tires looks great...I have them on my 2013 maxima southeast Houstone area
Old pic...i recently updated my rims and body work....will show later
Old Jul 8, 2022 | 01:33 PM
mahanddeem's Avatar
Nice Maxima.
Great idea to prevent people from driving on your lawn 👍
I am considering doing the same
Old Jul 8, 2022 | 01:36 PM
Nopike's Avatar
Looks fine. Best part is you have a bit more protection from potholes.
Old Jul 8, 2022 | 02:57 PM
Max2011sv's Avatar
nice!! Do you have any problems with tires rubbing the tire space if you go on bouncy road or have heavy weight in car?
Old Jul 8, 2022 | 07:33 PM
Reality sucks's Avatar
Old thread but ill chime.. I do tires Every day and I Love My maxima. The 45's should have been the stock option on the 7th gen Imo. Many Go with this size these days over the 40's Imo with the size of this car, its need some tire under it, The wheel gap killer.
Old Jul 8, 2022 | 08:43 PM
Max2011sv's Avatar
hi! Thank you for your reply. So you would suggest the 45’s are a good choice then. Would it rub against the wheel well if I have like 4 other people sitting in the car? Any limitations or issues? Aside from reading speedometer showing 2-4mph slower? So if it shows 60mph, I’m really doing 65.. ?
Maxima199
Mar 27, 2018 06:22 PM
Jarohnimo
Sep 6, 2012 07:51 PM
05MAXIJJ
Tires and Wheels
Apr 15, 2006 07:13 AM
maxedout2k1
Mar 5, 2003 03:34 PM
