Weird sound coming from passenger side
Old Jun 22, 2020 | 03:48 PM
jordan_drews's Avatar
I was hoping someone would know what this sound is(video attached) it’s not the engine or tranny, In the video the car is turned off and is coasting in neutral , so it’s something with the suspension.
Old Jun 22, 2020 | 03:55 PM
Bificus99's Avatar
No attachment.
Old Jun 22, 2020 | 04:04 PM
Sorry uploaded to youtube, the volume has to be high to be able to hear the noise
Old Jun 22, 2020 | 04:46 PM
LtLeary's Avatar
Man all I can hear is wind noise and a Peacock? Maybe another with the window up?
Old Jun 22, 2020 | 05:15 PM
My bad, here is a better video
Old Jun 22, 2020 | 07:30 PM
Bificus99's Avatar
Could be something as simple as a piece of debris in a dustshield or brake area, a bent dustshield or maybe a wheel bearing. I hear a cricket chirping sound for sure.
Old Jun 22, 2020 | 08:02 PM
I've noticed that the chirping sound gets faster as im accelerating, and slower when decelerating, would that be the wheel bearing?
Old Jun 22, 2020 | 09:25 PM
Bificus99's Avatar
That means its rotational and not engine speed. If you are good with tools take off the front wheel and visually inspect for a rock or debris and then repeat with the rear wheel on the passenger side. If you are uncomfortable with this ask around for a good recommendation for a mechanic to look it over.
Old Jun 23, 2020 | 07:11 AM
HeloMech's Avatar
Maybe a bad wheel bearing. I just replaced my because of the same problem. Different sound from mine but the same rotational type of noise. Does the sound speed vary with the speed if the car? If so, I’d bet money on the wheel bearing
Old Jun 23, 2020 | 08:03 AM
LtLeary's Avatar
Actually sounds like a belt squealing/slipping to me. Might want to check your belt and pulleys/tensioner.
Old Jun 23, 2020 | 04:49 PM
Thanks for all the suggestions, did some digging around and found that the dustshield had become detached and was rubbing on the passenger side. No more noise!
Old Jun 23, 2020 | 06:24 PM
HeloMech's Avatar
awesome! Easy fix!
Old Jun 24, 2020 | 06:32 AM
Bificus99's Avatar
Awesome!
pktaske
Mar 14, 2011 11:43 AM
LTU_max
May 25, 2008 12:35 PM
98maximer
Sep 21, 2004 11:47 PM
sk24iam
Jan 27, 2004 06:08 PM
