Shock and Strut Replacement
Old Aug 20, 2020 | 08:53 AM
mattz300's Avatar
Ive searched the forum and cannot find any good info on what I thought was a common topic. I believe coil overs is the way to go when shocks/struts are bad but I would like to learn more about them and how the installation happens. Are there any good threads on this that someone can link me to?
Old Aug 20, 2020 | 06:58 PM
User1's Avatar
The installation process is the reverse of the removal process. And since you'll only be doing one side at a time, you even have a guide with the untouched side of how the first finished side should look when it's done. Pretty neat, huh?
Old Aug 20, 2020 | 07:53 PM
WVJH's Avatar
I believe most coilovers if not all are adjustable. I haven't done it but I heard to install them, first remove one of the originals. Hopefully it's still in okay condition (mine are usually blown up). Use the original to set the coilover so that they are the same length top to bottom before install. Then adjust to hella low while all four are on. Gives you a solid basepoint I guess. Been eyeing a couple sets all over.
Kiron Kid
Dec 24, 2016 01:43 AM
FormorAccordMan
Mar 20, 2005 07:31 PM
gregfrantz
Dec 27, 2001 09:55 PM
Maxfreak
Apr 20, 2001 12:42 PM
