P0014, P0024, need help on 2014 maxima
Old Oct 30, 2020 | 10:58 AM
jerad's Avatar
Hello my car keeps giving me these codes and i don't know how to get rid of them, its starting to hicup or cut out for just a split second when going down the road once every now and then but nothing consistent... I've replaced cam sensors and cleaned the ivt solenoids but still same .. i keep oil changed regularly but do have 150k on car... any ideas would be greatly appreciated...
Jerad
Old Oct 31, 2020 | 12:04 AM
User1's Avatar
Those are EVT codes. And EVT is magnetic. But at least now your IVT stuff has been serviced.
Install a new crankshaft position sensor and call it a day.
Old Oct 31, 2020 | 04:43 AM
jerad's Avatar
Hello and thanks i will definitely try that, someone also said to replace the vtc also , whats your thoughts on that??
thanks
Jerad
Old Oct 31, 2020 | 01:23 PM
User1's Avatar
Define "the vtc"
Old Oct 31, 2020 | 04:26 PM
jerad's Avatar
Vtc
Variable timing control, where the solenoids are that control the timing... part # 13040-9N02A, 13040-JK24B from what i understand... and thanks for responding...
Jerad
Old Oct 31, 2020 | 05:48 PM
User1's Avatar
I wouldn't worry about that. Under your codes, the FSM lists testing of the magnetic retarder, but my money is on the crankshaft sensor.
Old Nov 16, 2020 | 08:41 PM
jerad's Avatar
Well I've replaced crankshaft sensor and still getting a p0014 code but haven't had it cut out or die on me yet so hopefully that's fixed but I'm not real confident in it since it still showing p0014... what else would cause this code ?? I'm hoping it's better now since it was dying on my daughter every now and then but I'd feel alot better if cel would stay off... any suggestions? Thanks
jerad
Old Nov 17, 2020 | 12:20 PM
User1's Avatar
Bank 1 exhaust cam is out of phase. Try swapping intake cam and exhaust cam sensors to try and replicate the problem on the intake side. Not sure what the code will be off the top of my head but it will be different. And don't worry about the sensors being different, they are the exact same part number.
Sotelo69
Feb 28, 2024 05:35 PM
Zay585
Jun 11, 2019 11:02 AM
sampdoria
Aug 24, 2005 11:18 AM
maxs4life
Oct 26, 2004 06:42 PM
pstark
Jan 17, 2001 08:30 AM
