2012 Nissan Maxima sv ran out of gas now will not start.
Old Aug 28, 2021 | 11:19 AM
Slipperyduckie's Avatar
Ran out of gas last night now it will not start. Fuel filter location? Is it built in with fuel pump?
Old Aug 28, 2021 | 01:24 PM
LtLeary's Avatar
The pump and filter are integral and located in the tank. Granted the pump is probably toast but did you check the fuses?
Old Aug 28, 2021 | 01:27 PM
I hear the pump priming on initial start. Any way the clean filter other than replacing the whole thing? Would the pump still make noise if burned out?
Old Aug 28, 2021 | 01:57 PM
Richard66's Avatar
A question and a suggestion. How much gas did you put in the tank? Prime the fuel system by running the fuel pump for a minute or two before starting.
Old Aug 28, 2021 | 01:59 PM
Have a half a tank in it like 6-7 gallons.. how do I prime I’ve been turning off and on the car. Meaning hitting the button twice till all the beeping stops and then off again done that multiple times. I’m thinking of just replacing the pump since I believe the filter is clogged
Old Aug 28, 2021 | 02:24 PM
Richard66's Avatar
The fuel pump primes the system by running. When you ran out of gas the fuel lines ran dry. Run the pump for a couple of minutes to prime the system before you attempt a start.
Old Aug 28, 2021 | 04:39 PM
The pump runs for a min then shuts off.. I’ve tried a lot of times turning it on and shutting it off.. I’m lost on ideas
Longpockets
May 17, 2020 12:23 PM
carriebeary
Jul 12, 2015 10:48 AM
-ReLLiK-
19
Mar 31, 2012 05:58 AM
benolin
18
Dec 19, 2009 10:05 AM
