Car shuts off while driving. Help needed.
Old Dec 25, 2021 | 10:26 AM
Moemoe29's Avatar
So I have 2009 Nissian Maxima, and for the second time my car has lost power and shut off. The VDC off and tire traction light comes on and boom its cuts on in mid traffic. I have replace the camshaft sensor & O2 Sensor. I read others and they said check the brake fluid and that is full to the max! What else could it be?? It runs fine all day and then boom the next day cuts off and I have to get towed or wait hours to finally drive. Help!!!
Old Dec 25, 2021 | 12:28 PM
LtLeary's Avatar
We could really use any diagnostic codes. What led you to replace those parts?
Old Dec 25, 2021 | 01:19 PM
Moemoe29's Avatar
I took it to Autozone and they told me it was those sensors. Today A New code just came up p1148
Old Dec 25, 2021 | 01:27 PM
Moemoe29's Avatar
Old Dec 26, 2021 | 05:18 AM
TDGrant's Avatar
Well, if your air-fuel ratio sensor is not working at all, which results in the code P1148, then that is a major issue leading to you not being able to drive the car.
Have a read - https://www.troublecodes.net/p1codes/p1148/
Old Dec 26, 2021 | 06:36 AM
LtLeary's Avatar
TD is on.point. i would suspect the new O2 sensor. Either the wrong type or installed on the wrong location. Either way, bad things will happen if A/F isnt correct. It may also be a clogged cat. But start with the O2 swnsor, where did you install it, what brand and PN?
Old Dec 26, 2021 | 07:29 AM
Moemoe29's Avatar
Thanks for replying back! I replaced the front O2 sensor and I purchased it at my local autozone.
Old Dec 26, 2021 | 12:39 PM
Bificus99's Avatar
Was it a Denso brand O2 sensor? These cars like OEM #1 Denso #2 and nothing else.
Old Dec 26, 2021 | 03:40 PM
Moemoe29's Avatar
yes It was a Denso Brand? So should I take it off and get the OEM brand?
Old Dec 26, 2021 | 04:38 PM
LtLeary's Avatar
I would also check the location. You stated you replaced the front one, but a p0301 is for bank 1, which is by the firewall if I remember correctly.
Old Dec 26, 2021 | 05:24 PM
Moemoe29's Avatar
Originally Posted by LtLeary
I would also check the lacation. You stated you replaced the front one, but a p0301 ia for bank 1, which is by the firewall if I remember correctly.
ok the code I got previously was P0031 for bank one.. So I should get P0301 instead? I also was advised to get the p1148 sensor too, for the close loop error code I got.
Old Dec 26, 2021 | 05:30 PM
LtLeary's Avatar
Sorry, i meant p0031. Bank 1 is by the firewall too. I would check my part numbers and locations.
Old Dec 27, 2021 | 07:49 AM
LtLeary's Avatar
Also, wanted to add, there are 2 different part numbers for these sensors (4 if you consider the ones after the cats)
The OEM part number you want for the Bank1 (p0031) is 226931AA0B and is probably responsible for your p1148 as well. Get that replaced and then lets check codes and see if your car does any better.
Your scan tool indicates 5 errors but you only shared 3. What were the other codes?
Old Dec 27, 2021 | 10:34 AM
Moemoe29's Avatar
OK, I order the Sensors they should be in this Tuesday. The codes I showed was the only ones that agent told me to take a picture of so he could check to see what the codes meant. I order a sensor for the p1148 which costed $179. should I hold off on that one and just get the P0031 Sensor for heater Bank 1
Old Dec 27, 2021 | 03:59 PM
LtLeary's Avatar
The 1148 is saying it cant talk to the O2 sensor causing the P0031. This is usually disconnected wire, bad sensor or WRONG O2 sensor. I dont know what other sensor you are referring to.
Old Dec 27, 2021 | 04:16 PM
Moemoe29's Avatar
oh okay.. The other sensors the agent told me to get was the AFR sensor, thats the high price one.
Old Dec 28, 2021 | 11:12 AM
Moemoe29's Avatar
I just took it to the Shop and they told me to replace the ECM for $1400. Said the codes change everytime they check them. Is the a reasonable price for what he has to fix?
Old Dec 28, 2021 | 12:23 PM
I suggest you find a new mechanic. ECM's don't go bad on this car. He's clueless.
Old Dec 28, 2021 | 12:24 PM
LtLeary's Avatar
i would get a second opinion. While 1400 for an ecm isnt bad, i highly doubt that is your issue.
Old Dec 28, 2021 | 12:25 PM
You need to be looking at the Engine Coolant Temperature Sensor....
Old Dec 28, 2021 | 01:35 PM
Moemoe29's Avatar
Ok, I will check that when I go to get my car back.
Old Dec 28, 2021 | 01:43 PM
Moemoe29's Avatar
They were my second opinion. Took it to Tripple A and they told me the didn’t know what it could be and to replace my Gear shift assembly. Something about the pin and how it doesn’t go into park or drive but that was a lie and they wanted $1100 to do that. But that wasn’t a problem. It only cuts off and the VDC off and Traction Light Comes On. It reduce speed and sooner or later cuts off. I hate that these shops isn’t truthful and honest about my car and it makes it no better than I am a female with no knowledge about cars
Old Dec 28, 2021 | 03:07 PM
User1's Avatar
The cam sensors are what's killing it while you're driving.
Old Dec 28, 2021 | 05:14 PM
Moemoe29's Avatar
Ok I already replaced the 1 camshaft sensor, but it was that denso brand, Im see if I can get the other brand that was mentioned before.. The heater bank 1 sensor came in today I can see if they will put it in and see it that works.. Do you know how many camshaft sensors there are?
Old Dec 28, 2021 | 05:28 PM
Bificus99's Avatar
How long have you had this car? Did you just get it and these issues popped up?
Old Dec 29, 2021 | 06:11 AM
Moemoe29's Avatar
Yes, I just got it in July and a month ago it started with this issue
Old Dec 29, 2021 | 01:05 PM
User1's Avatar
Four cam sensors and they're all the same part #. Stick with OEM for sensors. Nissanpartsdeal.com. Get a copy of the FSM and ID the sensors (bank 1 bank 2 "A" "B" etc)
NYC_Maxima97
35
Mar 18, 2018 10:00 PM
CCx
Aug 8, 2003 03:09 PM
maximumpower96
May 7, 2003 08:55 PM
