2012 Maxima Ignition Issues
Old Jan 17, 2022 | 04:46 PM
Stealthcanyon35's Avatar
Hello,
first time posting here.I have a 2012 Nissan Maxima S with a push start ignition. If the car has been sitting a while (like over night) it starts up no problem, even in 20 degree weather. If I drive it for 10 minutes to run errands and turn the car off, the car will not restart immediately. Sometimes I have to push the ignition start 20+ times which could take 5 minutes to get it running again. I swapped the battery with a new one out last week but the issue remains.
The push button cycles through off - acc - start without issue. I hear a click when I hold the ignition in to start the car but that’s it. I even tried putting the key fob in the key slot and that does not help. Any thoughts?
thanks for your help
Old Jan 17, 2022 | 07:22 PM
Richard66's Avatar
As I understand your post, car works great cold, not so great warm...Ok what happens when things get warm, they expand, and when cold they contract. I'm thinking starter wiring or connections a good place to start looking. Also take some voltage readings at the starter when the engine is hot. Low voltage or bad ground will keep the starter from turning over.
Markyb69
Jun 24, 2016 03:19 PM
nissan99
Feb 23, 2013 08:47 PM
1chewabacha1
Jul 8, 2009 01:41 PM
Mmmaxx
Aug 7, 2007 01:41 PM
