A/C Issues
Old Jun 10, 2022 | 05:15 AM
zacd's Avatar
Arrow A/C Issues
Hello All
Ok so i am having issues with my 2010 Nissan maxima 135k on miles Ive changed the AC compressor, drier, and the expansion valve, also the ipdm yet im still not having any luck the clutch does not engage not sure whatelse to do ive tried jumping out the pressure switch but the car dies out when i do that anyone have any ideas thanks in advance.
Old Jun 10, 2022 | 07:02 PM
Reality sucks's Avatar
Welcome
Did You check the Fuse in the IPDM for the ac Compressor.? often times the old Compressor can take out the fuse when it fails electronically.
Hook up a scan tool if you have access to one, You need to verify that you have a/c request via its data function from the control head.
I usually start by tracking the Circuit backwards from the Compressor. Verify power and ground here and follow it back Via the FSM untill you Find the problem..
It could be that there is something wrong with New Said Compressor if the engine is shutting down. Is it Locked Up..?
Old Jun 13, 2022 | 03:59 PM
AI4U's Avatar
Ac
There is a white wire that carries power from the control unit to the AC compressor,
check that wire for power. Remove the fuse box cover under the hood. If that line has power then you have power going to the compressor. Your problem is at the compressor.
Check the fuse as well as, previously stated!
It could be that there is something wrong with New Said Compressor if the engine is shutting down. Is it Locked Up..?[/QUOTE]
Old Apr 3, 2024 | 11:22 PM
wifevi4622's Avatar
click here to know more
pbytrailz
22
May 8, 2022 12:34 PM
51Magnum
May 2, 2018 06:52 PM
corbryant
May 27, 2013 12:41 PM
stas29
Oct 26, 2006 10:39 PM
ejj
Nov 2, 2004 06:19 AM
