No start and CPS codes.
Old Jul 21, 2024 | 09:50 AM
Zorothing's Avatar
My wife's 2010 3.5 is a no start after driving normally the day before. It had p0340 / p0345 codes. So I order 2 ntk cam position sensors.
After checking for signal voltage at all 4 plugs (5 v all around) I replaced the 2 rear (firewall side).
Still won't start.
SI I swap the 2 up front with the ones from the back side thinking maybe I got it wrong on the bank 1 being the rear sensors.
Still won't start.
seems to be getting fuel (afr spikes while cranking) and has no spark
I have checked grounds and done the jumper cable block to battery with no change.
​​​​​​Any help would be appreciated, I'm a bit stuck on this one.
I will attach a screenshot of trouble codes.
It also has a throttle body / throttle pedal code but has been running fine with them for a year+ (they appeared when the can was accidentally powered on when cleaning the throttle body and it was unplugged)
Mtk
Aug 12, 2023 11:25 AM
maxipriest777
Jun 29, 2023 10:06 PM
Carla
Jul 27, 2022 03:43 AM
Andrew
Feb 28, 2012 09:54 AM
gabex
May 17, 2003 07:47 PM
