P0171 Lean Bank 1
Old Feb 8, 2025 | 11:05 AM
Drgracen's Avatar
P0171 Lean Bank 1
And suggestions for a cure. O2 sensor is showing good activity on scan tool .... disabled each injector individually and all appear to be working ... no apparent vacuum leaks. What am I missing ??
Old Feb 22, 2025 | 01:56 PM
knoenuff2bndanger's Avatar
valves/ actuators on the plenum
Old Feb 24, 2025 | 06:04 AM
texasking10's Avatar
I had the same issue. I replaced both upstream O2 sensors and haven’t had that code pop up yet. Wasn’t fun getting the cab side O2 sensor. Have to remove the intake plenum.
I plan to replace the downstream O2 sensors at some point but those are hard to get to.
Old Mar 11, 2025 | 05:09 PM
Icecold's Avatar
P2095
I replaced my front 2 O2 sensors as bank one upstream was bad. (Replace in pairs). Then code P2095 came up the next day. Meter ran front 124 but downstream bank one was 104. Just ordered both downstream sensors. Did a smoke test and no vacuum leak detected. Hope this may help you.
Old May 10, 2025 | 12:43 AM
SCOPES DOPED's Avatar
which sensors did yall get?
Old May 12, 2025 | 01:23 PM
Icecold's Avatar
O2 Sensors
I ordered NTK24783, 24449,24450, and Denso 2349106
tbergma1
Feb 17, 2006 12:03 PM
Stalix
Feb 7, 2005 11:51 AM
Torgus
Sep 16, 2004 06:27 PM
Rickalodeon
Jul 10, 2002 09:11 AM
eaglclon
Apr 18, 2002 06:36 PM
