Intelligent Key intermittently not working
Old May 17, 2025 | 08:04 PM
ianm's Avatar
2010 7th generation Maxiua. Occasionally, using my intelligent key to unlock door does not work. Then use physical key to unlock. No Key sign shown on dashboard instead of "Brake". Can't start vehecle. Same for another intelligent key. !0 minutes later, everything back to normal. In the past, no key sign lasts only very shortly and everything works again. Has happened a few times before. Key batteries checked out. What could be the issue?
Old May 18, 2025 | 08:57 AM
Richard66's Avatar
Anytime I have electrical gremlins running around inside my vehicles causing headaches I disconnect the battery for 30 minutes to reset the computers. Most of the time this solves minor problems.
Old May 18, 2025 | 03:31 PM
ianm's Avatar
Thanks for the sensible suggestion. Will try that.
However, if I don't have immediate access to tools for disconnecting the battery, I think I could remove the ECM fuse to do the same, couldn't I?
Old May 19, 2025 | 10:56 AM
Richard66's Avatar
Not so much as this just resets the ECM. Battery disconnects reset a broader range of computer systems.
Old May 19, 2025 | 06:59 PM
ianm's Avatar
Thanks again.
Beachboy70
Jan 18, 2022 11:02 PM
Profireman
Nov 22, 2013 11:35 AM
mxo
Nov 4, 2003 11:00 PM
