Possible alternator problems
Old Sep 17, 2025 | 07:45 AM
Kaylalissner07's Avatar
Okay, so I hit a racoon in my car. And then a couple days later while driving my car, I lost all power in my gas pedal, so I pulled over and the battery and brake light started flickering. Then my motor started like spuddering so I turned my car off. A friend brought me a battery, I put it in and everything went back to normal. The next day A friend did the test where they took off the negative wire from the battery and the car immediately died. But my question is, couldn't this possibly be a wiring problem or a connector? I want to make sure it is a bad alternator before I buy a new one and try to put it in because from what I hear, it's pretty difficult.
Old Sep 22, 2025 | 04:53 AM
smeegle's Avatar
A simple load test can be performed. Most shops can/will do it at no charge. Turn the car on, turn all all accessories, ie. Headlights (high beams), stereo, A/C, Wipers, rear defroster, anything that draws power, then they measure the load. If it's not within spec, it's a failing alternator. You say you put in a new battery. If the alternator is faulty, that battery will die soon too. Failing alternators can kill batteries altogether and require replacing again.
rossp06
Apr 7, 2016 10:48 AM
Eric F
19
Dec 24, 2009 06:03 PM
racin89lx
Jul 2, 2006 07:46 AM
ejj
Aug 29, 2003 12:32 PM
davemax
Jul 30, 2002 07:19 PM
