New guy with p2099 code
Old Oct 3, 2025 | 12:38 PM
BrianS's Avatar
Hi all! I just acquired a 2014 w/ 77k for a pretty good deal. Just recently it threw a p2099 code:
The code P2099 on a Nissan Maxima indicates a "Post Catalyst Fuel Trim System Too Rich Bank 2". This means the engine's computer (Powertrain Control Module or PCM) has detected a rich fuel mixture in the exhaust system after the catalytic converter on Bank 2. Bank 2 is the side of the engine that does not contain cylinder number one.
I found a vacuum leak in the intake boot and fixed that but still get the code after driving for a few days. Does anyone know if this is a common issue or if there's an easy resolution to this?
Old Oct 6, 2025 | 07:41 AM
Richard66's Avatar
Did you clear the code with a scan tool? That's the only way to tell if your fixed vacuum leak was the problem. If the code comes back them additional diagnostics will have to be done.
Old Oct 6, 2025 | 07:58 AM
BrianS's Avatar
I did clear the code. Drove it a couple hundred miles then it came back which seems weird to me. I would think a leak would be present all the time and the code would have come right back. Also, would a vacuum leak only effect 1 bank but no the other?
Old Oct 9, 2025 | 01:35 PM
BrianS's Avatar
I rescanned it... The long term fuel trim table is showing 99-100 which is bad and apparently indicates a few issues:
low fuel pressure - i cant find the Shrader valve. Anyone know where its located?
vacuum leak - replaced the intake boot which had a tear but no change
dirty MAF - cleaned w/ correct MAF cleaner spray
clogged injectors - going to try and run injector cleaner
exhaust leak - haven't checked yet
Any thoughts?
bgruver
Jun 27, 2016 11:01 AM
Pyrophilus
Feb 1, 2005 06:29 AM
95terramax
Nov 1, 2004 03:59 PM
maximumsportZ
Jan 15, 2001 12:36 PM
