Strange Problem when I tried to start my Maxima
Old Apr 7, 2026 | 09:43 AM
Dynax's Avatar
Hi Everyone!!
I have a very strange problem with my Maxima Exclusive 2015. This is my sad history... Sometimes, when I push the start button the car simply doesn't start. I mean, it makes the noise of the "click" of the relays, moves the steering wheel, pass to "on" position, but nothing happens later. I don't have any dashboard light or similar, just doesn't start. It happens one or two times during a week. So, I need to push the start button several times in orden to start the engine. Sometimes I need to do it three times but I need to do it like ten times (even, I tried moven the stick from Parking to Neutral, or get out the car and re-enter, etc.) I couldn't find a pattern or a sequence when I had the failure. I had this issue for around nine months. When starts normally, I dont hear any strange noise feels everything fine. I looked for intomation about this problem, but I still don't get to the right solutions. At the moment, I did the following:
- Change the brake switch (located above the break pedal).
- Change the battery (key fob).
- Change the IPDM (about three weeks ago). I thought that the relays inside the power module could be damage.
- Change the car's battery (a week ago).
I was hoping that changing the battery might solve the problem, as it has a slightly higher amperage (575 versus 550 A), but yesterday I experienced the same problem again. Any ideas?? The starter moror could be?? Again, when the car starts, I don't hear any noise.As you can imagine, I'm desesperate... because it seems to be aleatorial. Sometimes happens at night, at morning or almost any other condition. But of course, sometimes I don't have any problem, I pushed the button and the car starts.
Thanks in advance!!!
Old Apr 15, 2026 | 01:22 PM
Dynax's Avatar
.I'm still looking for a solution... for now, it seems that if I switch the headlights from "AUTO" to "OFF", this problem becomes less frequent (about once every five days)...
Old Apr 20, 2026 | 02:45 PM
Dynax's Avatar
I looked for more information and it appears it will be the starter motor (or at least, the solenoid). I will change it next weekend, I hope this solved my problem.
Old May 12, 2026 | 03:49 PM
Dynax's Avatar
Well, yes, it was the starter motor. I changed it two weeks ago and so far so good!!
JY05
Oct 18, 2008 05:29 AM
mrbill
Apr 6, 2004 08:39 AM
Chris96SE
Dec 21, 2003 11:39 AM
GTKeeper
Nov 22, 2003 10:01 AM
