Are these splash guards on my 2016 Maxima?
Old Jul 20, 2015 | 12:59 PM
spazma7ik's Avatar
I was about to call to order splash guards as for some reason I thought they would look like mud flaps, but upon looking at nissan's accessories the image they show looks just like what I have here:
Front wheel
Rear wheel
Are these splash guards?
Old Jul 20, 2015 | 01:25 PM
Max8's Avatar
Yes
Old Jul 20, 2015 | 01:38 PM
spazma7ik's Avatar
Originally Posted by Max8
Yes
Thank you! Just saved me $150 from ordering something I didn't need.
Now my question is, how the hell do these help with anything? They seem so minimal..
Old Jul 20, 2015 | 01:50 PM
mrgooch's Avatar
Correct! Just a rip off. That could have been built into the design.Just as including Mats in all models forcing you to buy them.
Old Jul 20, 2015 | 06:22 PM
JRod28's Avatar
Just like the 7th Generation splash guards-- more cosmetic than functional...
Old Jul 20, 2015 | 07:29 PM
Max8's Avatar
Yeah, I was expecting a little more (although they show them in the brochure)
Old Jul 21, 2015 | 03:15 AM
lightonthehill's Avatar
Nissan Maxima splash guards have become more of a protector of the finish of the car in the area where pebbles, trash, etc, tend to be thrown up from the tires than guarding against moisture thrown up along the side of the car. I always buy four appropriately-sized mud flaps at a place like Pep Boys and carefully cut them down till they stick out to the side just to the outside edge of the tread (not the sidewall), and reach just around three inches below the bottom of the splash guards. I mount them on the bottom rear wall of the wheel well with stainless steel lag screws. In order to further hide them, I mount the usual 1" wide black hard rubber molding around the outside edge of the wheel well (helps block dings from careless nearby door openers), then sand the body-colored painted surface inside the wheel well and paint it black.
These give protection to the side of the car, and are so difficult to spot that nobody other than my friend who is the service manager at my dealer has ever spotted them. She misses absolutely nothing.
Old Jul 21, 2015 | 07:49 PM
Shmoopy's Avatar
Anyone else noticed the small rubber "mud flap" on the FRONT SIDE of the RIGHT REAR WHEEL well? No such thing on the other three wells (I checked).
This is a front wheel drive vehicle... so what is it? What does it do? And why just that side?
Old Jul 22, 2015 | 12:20 AM
I thought I recalled seeing that flap on the front of the FRONT LEFT wheel well on the one sitting on the raised platform in front of one of my dealer's lots. I am probably mistaken about which wheel well, but I did see that flap, and I was not able to figure out its purpose unless it stops gunk kicked up when we throw the car in reverse and spin the front wheels. Obviously not a normal splash guard or mud flap, as those only work on the REAR side of the wheels. I will ask my service manager the next time I see her. She knows everything.
Old Jul 22, 2015 | 07:52 AM
Max8's Avatar
I don't know what function they serve, but my Platinum has them on both sides.
Old Jul 22, 2015 | 07:54 AM
mrgooch's Avatar
They should have been part of the build.
Old Jul 22, 2015 | 04:46 PM
They definitely are part of the build. It is going to be interesting to find out their purpose.
Old Jul 23, 2015 | 03:08 PM
Shmoopy's Avatar
I do have them on both sides. Let me know if you find out what their purpose is. Thanks.
Old Jul 23, 2015 | 03:19 PM
Max8's Avatar
They lower the turbulence under the car and reduce aerodynamic drag.
Old Jul 23, 2015 | 05:52 PM
An answer that makes sense. Thanks, Max8.
Old Jul 23, 2015 | 07:44 PM
Shmoopy's Avatar
Get a Quote Today
Interesting... your theory or do you know for certain? Thanks.
Old Jul 23, 2015 | 07:58 PM
Max8's Avatar
Reasonably certain. Several message boards for different kinds of cars stated this. And it makes sense.
Old Jul 23, 2015 | 10:33 PM
Richard66's Avatar
Wouldn't they raise the air turbulence under the car. It would be like putting your hand out the window while moving down the highway, lots of turbulence. I bet those are supposed to be removed after vehicle delivery to the lot. My thoughts anyway.
Old Jul 24, 2015 | 12:11 AM
If they were supposed to be removed before putting the car out on the lot, then I can think of no reason for putting them on in the first place. But who knows? Maybe this does a little 'split' of the air to help divert it around the sides of the tire, rather that hitting the tire head-on?
Aerodynamics is a strange science. Things that seem 'streamlined' and 'aerodynamic' from our view are sometimes not the most efficient at moving through the air. Through the use of smoke and wind tunnels, we sometimes find the best air movement is obtained through odd-looking structures.
Example - When I put rain guards on my 7th gen, the wind noise at speed picked up noticably. I experimented with many different shapes and sizes of molding added to the molding along the bottom of the sides of the windshield just ahead of the outside mirror (and ahead of the rain guards), and the one that helped reduce noise the best was a rather strange combination of several shapes of molding. I know the next owner of my 7th gen is going to lay awake at night wondering what that strange concoction of extra molding is for.
Old Jul 24, 2015 | 07:14 AM
Richard66's Avatar
One person reported he has only one and another reported he had two of them. If they were part of the build wouldn't the cars have the same number?
Old Jul 24, 2015 | 07:27 AM
mrgooch's Avatar
There not easy to spot.
Old Jul 24, 2015 | 07:47 AM
Max8's Avatar
They are in front of the front wheels too.
Old Jul 24, 2015 | 09:04 AM
Shmoopy's Avatar
I do have two... it just wasn't easy to spot. Whatever it is, it's there for a reason.
Just seemed odd as I had expected the splash guards themselves to be more substantial, with something protruding downward like these do.
Old Jul 24, 2015 | 05:12 PM
That was the old days, Shmoopy. Maxima splash guards for over the last decade have been there to prevent pebbles and trash from hitting the painted surfaces, but have done very little to prevent glop from splashing onto the sides of the car. That is why many folks (including me) automatically grab mud flaps from any auto store and cut them way down to mount behind the wheels, sticking out to the side exactly even with the edge of the tread (not the sidewall), and sticking below the bottom of the car no more than three inches. They help keep the sides of my car clean, but nobody even knows they are there (except my service writer, who doesn't miss a trick).
Old Jul 24, 2015 | 08:43 PM
zoemayne's Avatar
The ones on the rear of my '10... They do actually serve a purpose. Nissan or no company would not hide parts which are intended for cosmetic enhancement. I hit some furniture debri that was on I95 and my front wheel deflected a large piece of wood to my rear wheel. Instead of hitting the tire and blowing it out etc it hit the guard with enough force to split it in half.... Also I hit a nail (I heard it deflect to my rear tire) and it did puncture near the sidewall area of my rear tire... I'm talking about the black flaps not the color matched pieces.
Old Jul 25, 2015 | 06:58 AM
Shmoopy's Avatar
That makes sense. Thanks.
Quickgtp
Apr 13, 2017 03:30 PM
MplsMadMan
Sep 4, 2015 02:23 PM
spidgeon
Aug 9, 2015 09:26 AM
xUNIxPanther
Aug 5, 2015 09:31 AM
BassAddictJ
Aug 4, 2015 11:38 AM
