Correct Eibach part number?
Old Apr 29, 2020 | 04:19 AM
  #41
kasdepwel's Avatar
Originally Posted by ENGINE2MAXIMA
Dam I just want enough low to cover some of the wheel gap. Why is this max so high from factory? It’s pretty high for a “sport” sedan.
It's well worth the trouble with the two sets of springs, if you can get your hands on some used sets it's not too bad. I ride on 20's and i get compliments on the ride quality a lot even with those skinny tires.
Old May 1, 2020 | 02:03 AM
  #42
Djgeorgecostanza's Avatar
Camber kits?
These all look awesome! I'm about to lower my 17 SV and was hoping to get a little clarification after reading through these posts.
So, the 63115.140s are the correct part number from Eibach but some are reporting issues with the front and bottoming out which is why some people are going 6392.140 for the front and 63115.140 on the rear. Is there an issue/problem/downside with just going 6392.140 all the way around?
Also, did anyone need a camber kit to go with their springs? I don't have much experience with suspension upgraded, I usually just stick to AV upgrades with my vehicles. My previous vehicle was a g35 6mt. The stock suspension was great so I never thought anything of upgrading. Due to wife pregnant with twins, I had to sell it for a sedan, so I'm trying to get back some of that fun "sportiness," so in a couple months when i feel like I'm about to lose my mind with two screaming infants, in addition to our current toddler, I can escape for a bit. (Joking, of course! I know I'll be at home through this, just want to make what little time I'll have away from the house going on diaper runs etc. As enjoyable as possible.)
Any additional insight is appreciated! Thanks!
Old May 1, 2020 | 05:22 AM
  #43
kasdepwel's Avatar
You can definately use these springs. They ride pretty sweet. You could get away without camber kits, but you'll be just a tiny bit out of specs. On the front, you'd use SPC 81260 camber bolts. They pretty cheap, You'll need 1 kit which get you 1 bolt per side, and for the back you can use a set of SPC 72295 but they're pretty expensive. I used a set of SPC 81250 camber bolts on the upper arms and i had plenty of adjustment.
Old May 2, 2020 | 03:15 AM
  #44
Oh great! Thank you so much for the info! Hopefully I'll be able to get this done in the next couple of weeks!
Old Apr 14, 2021 | 05:28 PM
  #45
ENGINE2MAXIMA's Avatar
Originally Posted by bghouse
hey jaxmax,
did you rear settle at all? Sorry to post on another old thread but just got mine installed & hoping these settle. I got like a little under an inch difference between the front & back after my alignment. Waiting to talk w/ eibach but hoping to get some feeback from the forum before i do. Thanks!!
did the rear ever settle??????
We need answers!!!!!
Im having same problem....
ClassicDriver
39
May 23, 2003 11:38 PM
mayhem_J30
Oct 7, 2002 01:06 PM
max2kgle526
Dec 3, 2000 05:28 PM
