Low Beam Headlight LED Kit
Old Dec 12, 2015 | 08:29 PM
MikePop16's Avatar
Question Low Beam Headlight LED Kit
Hey Guys
For anyone who switched out their halogen low beam headlights for LED's. Can you attach a link to the ones you chose. I would appreciate pictures also. Also if someone could explain how they got to the low beams through the wheel well.
Thanks in advance
Old Dec 24, 2015 | 08:31 AM
Christopher Stark's Avatar
anyone? Would like to know also. But so far, I found these....thoughts?
http://www.ebay.com/itm/JDM-ASTAR-70...-/231773359130
Old Feb 11, 2016 | 04:20 PM
mannino89's Avatar
Anyone else chime in on this? I'm torn apart, I wanted the SL but not having LED bulbs is deal breaker for me, what's the bulb size? Also, to any & all that have successfully done the swap, how's the output on thr stock projectors w a drop in HID/LED kit?
Old Feb 11, 2016 | 05:29 PM
Clouded's Avatar
Bulb size is H11, I haven't done the swap yet, but I have an HID kit ready from my old car whenever I have time.
Old Feb 11, 2016 | 08:07 PM
mannino89's Avatar
From what I'm hearing, these are the way to go for dropping in an LED kit. http://opt-7.com/opt7-fluxbeam-led-headlight/
Recently found out that the SL doesn't come w led low's & that's basically a deal breaker for me. Can't afford to go back to halogen coming from a 2013 VW CC Bi-Xenon factory set up. The dealer could put me in an SL for a reasonable price but I'm hesitant. Thinking of whether or not a led drop-in kit would give me issues w dealer for warranty work just gives me a headache. SR & Platinum price range for lease are just way too high....pretty bummed right now...we'll see
Old Nov 5, 2016 | 08:59 AM
bebanoscar1's Avatar
LED fog lights, Tint, Niche M150 20x10 255/35/20 +40.
Waiting on STILLEN
add ons.
Old Nov 5, 2016 | 07:58 PM
tmokorn's Avatar
Originally Posted by bebanoscar1
Waiting on STILLEN
add ons.
In my personal opinion, hid's from trs would be the way to go. I purchased and installed the SNGL 5k led headlights (link below) and have only kept them since I have the diode dynamics 5k xml2 led fogs - as the fogs illuminate farther and wider than the headlights themselves. It is dangerous to drive with only the headlights on as the cutoff is insufficient. Although the beam pattern is level, there are no hotspots so the intensity and throw do not match the stock halogens. I purchased them to have all forward lighting match the daytime running lights without manipulating the extra wiring of hid's as these were plug and play - not that they were any cheaper. When and if the LED's fail, I will make the switch to the morimoto kit. Pretty sure that the stock halogens in my SL outperform the LED's in every aspect except the color. My vehicle is shown on dd website customer images for reference. This is a duplicate of multiple headlight threads, but hope this information helps.
LED headlights: https://www.amazon.com/SNGL-Headlight-Conversion-Adjustable-Replaces/dp/B01FAPRARK?th=1&psc=1
LED fogs:
http://www.diodedynamics.com/store/led-bulbs/listed-by-vehicle/nissan/maxima/2007-2013-nissan-maxima-fog-light-leds
Old Nov 16, 2016 | 04:20 PM
MaxJoe75's Avatar
For those of you guys that have upgraded to LED headlights, do we need to purchase the decoder as well?
Old Nov 16, 2016 | 04:23 PM
tmokorn's Avatar
Not if the output wattage is the same as stock. Refer to the user manual for the wattage of each bulb. Typically only small bulbs like turn signals and parking lights have significantly less draw and require a resistor.
Old Nov 16, 2016 | 04:40 PM
MaxJoe75's Avatar
Thank you sir.
Old Nov 16, 2016 | 06:58 PM
chiefy's Avatar
i swapped to hid myself... very easy thru wheel well. I removed wheel for easier access.. a few clips and pull back and liner.. bulb is h11 while ur there get the led fogs done... H16 jdm astar from amazon 2 sets $25 each 4 bulbs total for fogs!
Old Nov 17, 2016 | 11:25 PM
Ian B's Avatar
Chiefy;
Can you post link of where and what model for the hid bulbs you got them from please.
Tia,
Ian B
Old Nov 18, 2016 | 11:40 AM
chiefy's Avatar
my hids are from ddmtuning.com 35watt slim ballast kit 6000k $44 shipped
I just put the opt 7 6000k small ballast kit in my wifes 17 pathfinder and seems good also and lil cheaper 26.97 shipped... use code email10 for 10% off..
Old Nov 19, 2016 | 06:39 PM
Ian B's Avatar
Chiefy, here is what I selected on the page from link you sent me. I am looking for them to be white and not blue or yellow. Let me know if I need to go to the 6k bulbs to get white.
Wattage * 35w
Bulb Type * H11
Bulb Color * 5000
Mounting Brackets ------do I need to order this item
HID Harness -------do I need to order this item
Error Eliminator -------do I need to order this item
Adaptor cables ------do I need to order this item
Found these in youtube also. What doez everyone think? https://youtu.be/ai28QXMMB2U
Tia,
Ian B
Old Dec 3, 2016 | 03:02 AM
jjohn1777's Avatar
For anyone interested I bought and installed the OPT7 H11s. They were OK but as pointed out in some of the reviews the down road throw is a little weak. So I ordered these from The Retrofit Source (TRS)
https://www.theretrofitsource.com/le...o-2stroke.html. Significant improvement in overall brightness and more importantly down road throw is much improved. OPT7s and Morimoto 2Stroke are the same price $100. For the money the Morimoto 2Stroke are much better and worth trying if your looking to go LED. Can't compare to HID or the OEM LEDs on the Platium as I haven't seen either but more than satisfactory as far as I'm concerned. The warranty on the Morimoto site is 18 months. TRS warranty is 3 years. We will see if they hold up.
Old Dec 3, 2016 | 10:38 AM
Ian B's Avatar
JJohn1777
Can you tell me if they are white, blue in color? Are they 5k, 6k, or other brightness?
Ian B
Old Dec 3, 2016 | 01:10 PM
jjohn1777's Avatar
They are white. 6000K. Not a perfect match to the DRLs but close. The OPT7s are rated at 3500lm per bulb. The 2Strokes are rated at 5000lm per bulb.
Old May 8, 2017 | 05:26 PM
Ian B's Avatar
Just ordered this led conversion kit after looking at Honda Accord w them on for $119.99. Let me know if anyone hss them.
https://www.xenonhids.com/low-beam-h11-led-headlight-kit.html
Ian B
Old Jun 3, 2017 | 06:24 PM
LB17's Avatar
Thanks for your post. I am about ready to make the same move on my SL and I would like to know this first: Would you say that the throw of the TRS system is equal to or superior to the original halogens? You compared it to the OPT7 and mentioned that it was significantly better... do you think that it also applies to the halogens?
Thnks again.
Old Jun 4, 2017 | 12:40 PM
jjohn1777's Avatar
Thnks again.
I would say the down road throw at least equals the halogens maybe a little better. Definitely brighter.
Old Jun 4, 2017 | 02:20 PM
calabs's Avatar
Just to add to jjohn's comment, stock halogens only have about 1350 lumens. The 2strokes' real-lumen output is about 3 times that. I have the 2strokes and i love them.
Old Jun 4, 2017 | 10:19 PM
LB17's Avatar
Yes, I know, but LED's need to be more powerful because they don't reach as far as halogens. They are super bright, sometimes even blinding bright, but don't reach as far as a good halogen bulb.
But you and jjohn1777 convinced me that they are a great buy so I'll definitely give it a try. Thanks for all the info.
Old Jun 27, 2017 | 10:27 PM
Hid Retrofitkit's Avatar
You are right on the money. The bulb blocks the light inside the projector causing a dark spot, a lot of output is lost with the led and that is the real deal leds. get a true hid system instead. My source is vanquishauto.com for the hid systems, we do more retrofits than anything.
MikePop16
May 30, 2016 09:17 AM
98nismomax
Mar 11, 2016 09:08 AM
Arikan89
Dec 10, 2015 09:01 AM
kmax13
Dec 9, 2015 06:07 PM
