High pitched whine at WOT?
Old Mar 19, 2016 | 07:20 AM
Max16SR's Avatar
I've recently noticed that if I am completely stopped and then floor it, the transmission or engine seems to make a weird high pitched whining noise as the rpms go up. If I am moving at 10 mph before flooring it, the car doesn't make the whining noise. Can someone try this out and see if it's normal?
It does it whether in normal or sport mode, and with traction control on or off.
Old Mar 20, 2016 | 04:43 AM
Roy2882's Avatar
No this isnt normal. The only whining noise you should hear (not necessarily) is a high pitched whine coming from the fuel pump which is a common issue for a lot of maxima's. You will hear this sound when you turn the steering...even if you are not moving. If the sound is from the fuel pump then there is nothing to worry (there is a seperate thread on this topic). If not, then better get your car checked at the dealer asap.
Can the noise be heard only when you are in the car? Ask someone to stand outside while you drive away to see if they can hear it. If it can only be heard inside....Im thinking fault with Active Sound Enhancement via the speakers maybe??
Old Mar 20, 2016 | 02:27 PM
Mike_TX's Avatar
Supercharger whine?
Just kidding.
Old Mar 20, 2016 | 08:41 PM
Max16SR's Avatar
Thanks for the tip on the active sound enhancement. I'll have to test that out to see if it might be it.
Lol at the supercharger comment. Now that you mention it, it does sound similar to a supercharger whine except that it isn't consistent
No one else has any issue with whining during WOT acceleration from a complete stop?
tallblazer124
Mar 14, 2016 08:39 AM
chevyman1980
Mar 5, 2016 05:17 AM
brichi
Mar 3, 2016 01:08 PM
tmorales509
Feb 29, 2016 05:08 PM
slickblack94
Feb 29, 2016 10:33 AM
