Cold air intake
Old Mar 27, 2016 | 10:16 AM
Benjamjr95's Avatar
Cold air intake
Been thinking of getting a Cold air intake, but I don't know which one is better between stillen and k&n cold air intake, can anyone help
Old Mar 27, 2016 | 11:24 AM
Richard66's Avatar
Neither one of those will give you a cold air intake. Your stock setup is a CAI as it takes in air from outside the engine compartment. The two you propose take air from under the hood whick is a lot hotter, and not a good idea. With Stillen or K&N you will get a lot more noise from the engine, but less performance off the line.
Old Mar 27, 2016 | 05:39 PM
urdunfer's Avatar
I installed a K&N. I had to modify the mounting bracket since it was interfering with the shift linkage. The sound of the intake is the only difference.
Old Mar 30, 2016 | 04:21 PM
Bodypro's Avatar
Having issues after installing my K & N air intake on my 2016 Maxima, will not go into drive with heat shield installed. Any suggestions?
Old Mar 31, 2016 | 01:28 AM
The post above stated that the mounting bracket had to be modified because it was interfering with the shift linkage. Maybe something along those lines?
Old Mar 31, 2016 | 11:29 AM
A36-SR's Avatar
You have to cut the heat shield under about the shifting cable
https://maxima.org/forums/showthread...46#post9086746
Old Mar 31, 2016 | 01:31 PM
Yeah, read the post above yours.
Old Mar 31, 2016 | 04:32 PM
Team STILLEN's Avatar
Former Sponsor
The STILLEN Intake doesn't have any fitment issues.
This is not actually the case. The Stillen intake uses the factory air duct and the less restrictive design does give performance increases.
Old Mar 31, 2016 | 04:57 PM
^ Does Stillen have a Dyno graph they can share which illustrates said performance increases? Thanks.
Old Apr 1, 2016 | 09:32 AM
NmexMAX's Avatar
dot dot dot ...
Still wondering how you dyno a CVT.
*edit, never mind, google is a wonderful thing.
Little weird.
Old Apr 1, 2016 | 05:09 PM
Maximam's Avatar
I have asked you guys over at Stillen in the past to provide IATs with your intake vs factory with hood closed and I never get a response.
Claims of performance increases but no data. I'm not interested in open hood dyno results.
Old Apr 1, 2016 | 05:10 PM
Maximam's Avatar
The inconsistency with a CVT makes dyno results unimportant to me.
Old Apr 2, 2016 | 09:50 PM
Bodypro's Avatar
Anyone have issues with the "MIL" engine light staying on after the intake install?
hacura3000
Mar 27, 2016 07:22 PM
mclasser
Mar 27, 2016 04:08 AM
mrgooch
Mar 24, 2016 07:34 AM
lowriderman3
Mar 22, 2016 08:10 PM
lowriderman3
Mar 9, 2016 06:13 PM
