HID Install - with Pictures
Old May 31, 2016 | 07:19 AM
  #41
Marc (NJ)'s Avatar
Originally Posted by chriscummings83
This my 5000k which to me is a little yellow.
5000k next to LED
5000k next to LED
5000k next to LED
Those 5000k look spot on to the LED DRL to me. From what I read, 4300k is the most light output, so going above 5000k you will lose output/distance.
Old Nov 18, 2016 | 02:13 PM
  #42
MaxJoe75's Avatar
Where do you mount your ballast on the passenger side?
Old Nov 18, 2016 | 03:18 PM
  #43
chiefy's Avatar
any one use the blitz bullet kit from OPT7?
Old Dec 19, 2016 | 08:51 AM
  #44
Jrsuperstar88's Avatar
I recently changed all my lights to HID and blew the fuse on my fogs as well. I looked in panel next to battery and can't find the fuse for the fogs. Can u tell me which one and where it's located. I've looked inside under steering wheel and under the hood next to battery. Didn't see it.
Originally Posted by tc8510
You will mount all ballasts.
When changing fogs the 15A fuse will blow so I upped it to a 20A fuse and all is just fine.
Old Dec 21, 2016 | 08:53 AM
  #45
Prophecy99's Avatar
I feel like the 5000k is too yellow. And the 6000k are too blue. Has anyone been able to match the color of the LED
OP i know this was in MAY, but what did you end up doing?
i agree with everything OP said, maybe different brands at same kelvins will help?? if i had to pick one u already had id go w 6,000k
Old Dec 22, 2016 | 03:42 AM
  #46
mfshehri's Avatar
I did installed this one "Blitz II Series: 35W S2 HID Kit"
Looks great, one bulb burned and asked for replacement. They were responsive and asked me to do some test to know which part should be replaced.
not so bright but it's good specially in dark areas and roads.
hope this helps
Old Dec 22, 2016 | 09:27 AM
  #47
Marc (NJ)'s Avatar
I had the OPT7 35w kit. http://www.ebay.com/itm/OPT7-35w-HID...vwFW-A&vxp=mtr
It sucked. No light output and 5k bulbs were very blue as I think the ballasts were garbage.
Switched to Innovited 35w 4300k AC kit. Night n day difference, and the 4300k matches the DRL pretty good. http://www.ebay.com/itm/Innovited-AC...l5FXfQ&vxp=mtr
Old Dec 23, 2016 | 09:12 AM
  #48
09Maxima_Sam's Avatar
Sorry to Hijack the thread. But I figured this may be the best place to ask. Where is the up and down adjustment of the headlight capsules? I looked under the hood but could not find it. A pic would be great.
Old Dec 23, 2016 | 08:52 PM
  #49
0107robin's Avatar
Draw is less. 5000k are white ish with a 1% hint of yellow.
I'm gonna try 6000k to see if I can get it to match the the LEDs. White with a 1% of blue tint.
I think the 6000k will work perfect, I installed them for my fogs and are amazing.
Old Jan 2, 2017 | 08:39 AM
  #50
0107robin's Avatar
Originally Posted by biftikhar1989
Want to start by saying thank you for your post, it was very helpful and gave me the confidence to take on the install. My previous 2010 Altima was a hassle to install HIDs as I had to remove the bumper.
I was able to install both in under 30 minutes, all from the top, without having to go through the wheel. The driver side was a breeze and took about 10 mins. The passenger side was a little more challenging since this is less access, but if you can squeeze your hand in, you can install it from the top.
I went with a 6000k Kit from OPT-7 (all plug and play, didn't have to splice any wires)
Have you done or planning to do the high beams too?
Old Jan 5, 2017 | 08:19 PM
  #51
EdOz's Avatar
For those of us who want to match the headlights to the LED DRL's...anyone know the Kelvin temperature of the OEM DRL?
Wouldn't knowing that give a better idea as to whether to choose 5000K or 6000K HIDs?
Old Jan 5, 2017 | 08:22 PM
  #52
0107robin's Avatar
I think that 5000K will be the closest, cause 6000K is nothing close in my opinion base on my car bulbs. I installed 6000K on fogs and is not the same.
Look at Marc comment, he said that 4300K match the DRL color temp.
Old Jan 5, 2017 | 08:36 PM
  #53
EdOz's Avatar
Thanks, Robin. As with many things, across the internet this subject draws different answers with each poster claiming that their's is the correct one. Perhaps the OEM DRL LEDs are different in temperature for different brands/models.
The consensus, as far as I can tell, comes down to either 4300 or 5000, with some outliers going for 6000.
Old Jan 5, 2017 | 08:54 PM
  #54
0107robin's Avatar
I don't think 6000k will do, if I were you will try 4300/5000. Blessings
Old Jan 5, 2017 | 09:08 PM
  #55
rdhunna's Avatar
Look at page 103 of http://www.nicoclub.com/service-manu...6%20Maxima/EXL
Old Jan 5, 2017 | 09:10 PM
  #56
rdhunna's Avatar
I've tried 4300k and its yellower than the DRLs.
5000k seems to be the closest that I've seen so far.
Old Jan 14, 2017 | 12:40 AM
  #57
maxkila's Avatar
I got my retrofit headlights with Hidretrofitkit company but I got my hid lights kit from www.vanquishauto.com
I love my headlights hid lights, they sold me a 55w kit and it is super bright. I will recommend this kit to anyone !
Old Jan 14, 2017 | 12:53 AM
  #58
maxkila's Avatar
Thumbs up My 2016 Nissan Altima xenon Hid lights headlights and fog lights
I will be posting images of my hids from vanquishauto as soon as I upload then to my PC.
Old Jan 15, 2017 | 06:23 PM
  #59
Talivan0116's Avatar
Here's some pics of the HIDS set up in have on my maxima .
55 watt 6000k on low beams
6k lows with 55 watt ballast and 3000k fogs with the neon film.
6000k Diamond white so it can match the led daytimes
Old Mar 30, 2020 | 08:38 AM
  #60
codereddew's Avatar
Originally Posted by Clouded
H11b
Sorry to bump an old thread, but is this confirmed? Also, should I get an HID kit with or without a relay?
djloveu
Apr 9, 2018 05:54 AM
im not gay but $20 is $20
Jan 5, 2017 06:47 AM
Publixman99
Mar 19, 2016 03:17 PM
Paratrooper3637
Wheels/Tires
Mar 16, 2016 04:25 PM
lowriderman3
Feb 23, 2016 11:28 AM
