Anyone tried flashing brake light install?
Old Aug 14, 2017 | 07:25 PM
Ian B's Avatar
Just ordered a set from here after watching you tube video below. Let me know how you like them if already have them installed.
https://blinkingbrakelights.com/
You tube video.
https://youtu.be/f2RgbwXlV78
Ian B
Old Aug 15, 2017 | 05:28 PM
Jlkoh102812's Avatar
I was actually looking into that blinking brake lights.
I was going to order it but the guy told me I might need the resistors for it. Did you order just the 7440 bulbs?
Old Aug 16, 2017 | 12:28 AM
Ian B's Avatar
No, I ordered the 7443 like he said should work. Will see. They just shipped to me.
Ian B
Old Aug 16, 2017 | 05:47 AM
White Fang's Avatar
Thank you for the post! I order a pair also...Found a 10% discount code to enter on checkout, JSUN
Old Aug 16, 2017 | 08:22 AM
Why did he say 7440 to me? Weird. Anyways give us an update when you install it to your brake lights.
And thanks for the promo code WhiteFang.
Old Aug 16, 2017 | 10:13 AM
White Fang's Avatar
I ordered the 7440 led bulbs after verifying the size at a few sites. The 7443 housing is different due to 7443 being dual filament as 7440 is single. Either will work😉
Old Aug 16, 2017 | 08:27 PM
Okay let me know if you guys install it and how you guys like it!
Old Aug 16, 2017 | 11:09 PM
Ian B's Avatar
Should get them friday or Saturday and will install Sunday Hoping they work like a champ.
Ian B
Old Aug 17, 2017 | 07:48 PM
me9798's Avatar
you want road rage?...install those.
Old Aug 17, 2017 | 11:07 PM
Ian B's Avatar
Only if you live in New York. Not down here in Texas.
Ian B
Old Aug 18, 2017 | 04:32 AM
A36-SR's Avatar
I think is a bad idea to, you can shot here in az they will think you doing a brake check , special people here like to drive nascar style on our, @ss.
Old Aug 18, 2017 | 07:50 AM
White Fang's Avatar
We are trying to avoid rear end collisions to now potentially causing road rage😏 Those angry drivers will always find something(loud music/HID Headlights/Fog Lights/LED Tails...)
I am sure it will do more good than bad but if issues come up...There is a easy fix😆😆
Old Aug 19, 2017 | 12:29 PM
Ian B's Avatar
They came in mail today. Here is a picture. Will install tomorrow and post.
Ian B
Attached Thumbnails Anyone tried flashing brake light install?-20170819_140252.jpg
Old Aug 20, 2017 | 09:09 AM
Ghwk's Avatar
Hi all, newly registered with a 2016 SR. I just ordered the module mentioned in one of these threads. Should I just have ordered the bulbs instead? Also, on the module install did any of you buy more than one for each tail light or did you just use it for the brake light on the upper deck above the rear seat? I may have not been entirely clear when I ordered.
Thanks for the help.
Old Aug 20, 2017 | 10:50 AM
BlakMaxiJoey's Avatar
if you want all to flash, install it on the brake switch by the pedal.
just the corner brake lights, yes, you will need two.
or, one for just the spoiler or 3rd brake light in-cabin.
at least, that was the instruction that came with the module i bought.
Old Aug 20, 2017 | 12:30 PM
Ghwk's Avatar
I guess if I can figure it out l'll do the install on the rear deck light.
Still unclear if all I needed was just flashing bulbs though.
Old Aug 20, 2017 | 02:49 PM
Ian B's Avatar
Here is video of my blinking brake lights just installed by myself. It took 20 mins to remove tail lamps and replace.bulb w LEDs.
https://youtu.be/6wjYbmins00
Ian B
Old Aug 20, 2017 | 02:52 PM
Ghwk's Avatar
Ian B
Thanks Ian. I probably should have just gotten those. They look great!
Old Aug 20, 2017 | 02:55 PM
Ian B's Avatar
I will report back if I get any gestures or look because of them. If you are doing the break light, that module needs to go between harness for 3rd light and spoiler LED cable or 3rd rear deck light wiring. That way it will do its thing before it gets to brake light
You can always return it and get the LED bulbs.
Ian B
Old Aug 20, 2017 | 03:06 PM
Ghwk's Avatar
Ian B
I don't have a spoiler so I was going to install the module at the brake so all the brake lights would be in sync but the instructions are awful and after crawling under the dash I wouldn't know how to isolate the correct wires without detailed instructions.
Old Aug 20, 2017 | 03:22 PM
Ian, you didnt need no resistor kit or anything?
You just switched the stock bulbs from the brake lights to the blinking led bulbs right?
Just plug and play?
Old Aug 20, 2017 | 04:07 PM
Ian B's Avatar
Just plug and play?
Correct, plug and play.
Ian B
Old Aug 20, 2017 | 04:19 PM
Can you record one video at night so I can see how it looks like? Thanks Ian!
Old Aug 20, 2017 | 04:40 PM
Ian B's Avatar
You read my mind, I was planning on doing this tonight and posting. It wont be till after 8pm cst when it gets dark here.
Ian B
Old Aug 20, 2017 | 06:37 PM
Ian B's Avatar
Night version with car running.
https://youtu.be/fgGCqCQImWg
Night version w engine off.
https://youtu.be/4RfDUfrZ9ic
Ian B
Old Aug 20, 2017 | 06:54 PM
White Fang's Avatar
Niccceee! Thank you for the post about the mod! Now I just wonder how the following would look on our cars:
https://www.diodedynamics.com/store/...category/1441/
Old Aug 20, 2017 | 07:54 PM
Ian B's Avatar
Not for me.
Ian B
Old Aug 21, 2017 | 06:49 AM
Ian B
Very nice! Now I am going to have to order one!
Is it bright though?
Old Aug 21, 2017 | 07:27 AM
cool bulbs! way easier that way.
Old Aug 21, 2017 | 08:04 AM
Ian B's Avatar
Yes, as bright as any led bulbs. Def worth the money. They complement the tail lights very well without being too oberwhelmed.
Ian B
Old Aug 31, 2017 | 10:02 AM
Ghwk's Avatar
How're the lights working out?
Old Aug 31, 2017 | 10:06 AM
Ian B's Avatar
Perfect and no dirty looks or rage from folks driving behind me
Ian B
Old Aug 31, 2017 | 12:30 PM
Ghwk's Avatar
Well just went to the dealer to ask about installing the module and was told it will invalidate the warranty, they went so far as to say the bulbs violated the warranty as well. The module install involves cutting wires so I sort of get that. The light bulbs I don't get since there is no cutting. The explanation from the mechanic was that the voltages were so sensitive that due to the way the brake system was set up the aftermarket parts could cause other brake and electrical system issues.
I'm going to hold off on the module but still considering the bulbs.
Old Sep 1, 2017 | 11:20 AM
lindros2's Avatar
This is totally true - messing with bulbs invalidates warranty, since there is an increase in fire risk.
I've seen multiple cars (notably a BMW 330i) with incinerated rear ends due to bulb issues.
This is a rice mod, in my opinion. I actually think it's illegal - German cars have "variable" taillights where more of them light up (and brighter) with max brake pedal pressure.
Old Sep 1, 2017 | 12:35 PM
Ian B's Avatar
To each its own by it's my car and I can mod as I please. If invalidates warranty I have auto insurance to cover it. So far after 2 weeks, no issue w them or any of my license plate, interior, vanity or door LEDs installed.
Ian B
Old Sep 1, 2017 | 12:45 PM
lindros2's Avatar
Ian B
Yeah bro it's your car so feel free to break the law. You can do it as you please and risk a fire, but in the meantime, I'd put some cash aside should you get a ticket. If you please.
The idea is to warn following drivers of a sudden stop from cars ahead. But U.S. government regulators say brake lights are allowed to do only one thing: glow more brightly than the taillights. Flashing is off-limits.
http://www.popularmechanics.com/cars...-let-you-have/
Old Sep 1, 2017 | 11:35 PM
Ian B's Avatar
sure.
Ian B
Old Sep 2, 2017 | 12:46 PM
short burst of flashing red should be fine.
cops had been around me, and no problem.
unless it is constant flashing, brake applied, then, that may be a different case.
it looks like hazzard lights that way.
Ian B. - your bulbs does a short flashing in the beginning only, right?
Old Sep 2, 2017 | 06:38 PM
Ian B's Avatar
Yes quick blinking for a second and then stay solid. No driver has flashed me or raged while using them. Almost like if you were pumping brake pedal.
Ian B
