Nissan maxima with tranny code code p17f1
Old Nov 23, 2017 | 12:57 PM
A36-SR's Avatar
I got me a new Snap on scanners, so i can make some changes on my ecu. So i did a full scan on my car it scan everything including radio lol , my surprised i got a p17f1 judder code on my tranny thats not good am calling the dealer tomorrow, but the crazy part is the my tranny fells fine with no issues i use my paddles shifter all the my i drive my car like a sports car and i don’t get any judder.
Old Nov 23, 2017 | 02:28 PM
Fishlet's Avatar
Maybe you got a scanner that can see the future? :-)
Well maybe you can ward off a problem before it becomes serious.
Old Nov 23, 2017 | 05:02 PM
dochidalgo's Avatar
Maybe you have read this......
http://www.therealmac.net/maxima/NTB15-015b.pdf
Old Nov 23, 2017 | 05:10 PM
A36-SR's Avatar
Yes , was not happy went i found that page online, will my new scanner can check every sensor,computer and electronic piece on the car. I got this scanner because i can change settings on the ecu like idle i like to set my at 900 on summer and timing advance with i have 2 +, top speed set at 160 and full throttle. Just can’t tune but am doing better then other tuner because they cant not offer those changes yet Upreve and bull dog.
Old Nov 23, 2017 | 07:53 PM
dochidalgo's Avatar
May I ask you which Snap on scanner did you purchase??
Old Nov 23, 2017 | 10:01 PM
realmac's Avatar
Originally Posted by dochidalgo
Thanks for linking to my site. I should buy one of those devices to connect to my computer. Just curious to see if any codes are being thrown in general.
Old Nov 24, 2017 | 08:46 AM
A36-SR's Avatar
I got this one because i have a fleet https://store.snapon.com/Diagnostics-C700040.aspx but you can get this one for less money https://automotiveequipmentspecialis...iABEgJF_fD_BwE.
Old Apr 27, 2020 | 10:43 AM
Ari Hanono's Avatar
Hola yo tambien tengo el codigo p17f1,
maxima 2016
el coche funciona perfecto. Quería saber que debo de hacer o como quitar este codigo?
Gracias
Old Apr 27, 2020 | 11:35 AM
ENGINE2MAXIMA's Avatar
With those settings on do you notice a difference in performance?
Old Apr 27, 2020 | 06:46 PM
kasdepwel's Avatar
maxima 2016
Gracias
Hola, si tiene este código, debe reemplazar el cuerpo de la válvula o reemplazar la transmisión.
Ese es el código que tenía en mi automóvil y reemplazaron mi transmisión.
Old Apr 27, 2020 | 07:23 PM
compyelc4's Avatar
We need some translation here.
Old Apr 27, 2020 | 07:27 PM
kasdepwel's Avatar
I wrote something in English then translated to Spanish. I said I had the code and they either swap the valve body for this or replace the transmission. They replaced my transmission.
Old Apr 28, 2020 | 04:54 AM
Mr.Santos's Avatar
CRAP now am worried about my 2018SV, now am going to have to buy a scan snap!!
Old Apr 28, 2020 | 05:58 AM
kasdepwel's Avatar
I think there’s only one that read the transmission codes. You’d’ll need an Android phone and cvtz50 app and a obd Bluetooth adapter.
Old Apr 28, 2020 | 07:34 AM
compyelc4's Avatar
You mean a Snap-On Professional Scanner, right? Punctuation helps.
Old Apr 29, 2020 | 05:24 AM
Mr.Santos's Avatar
REALLY FML! on top of that i dont have in Android smh..well my girl has one but still, mite just take the chances and pray the CVT holds up with no problems.
Old Apr 29, 2020 | 08:17 AM
BlakMaxiJoey's Avatar
following. the dealer slapped my face with both codes... said, "we need to replace."
Old Apr 30, 2020 | 04:52 AM
kasdepwel's Avatar
My dealer had to open the transmission and and check if there was any scars on the sheaves faces. If there's marks on the sheaves, they replace the transmission and if there's none, they replace the valve body. That's what they said. However when they opened the valve body to check, there was a lot metal shaving in the fluid, so they replaced my transmission.
Old Apr 30, 2020 | 04:54 AM
kasdepwel's Avatar
Me neither, bud i was able to check the codes with my chromebook. If you're still warrantied you should have a look, a transmission change here cost at least 7k.
Old Apr 30, 2020 | 06:00 AM
robtroxel's Avatar
It's a known issue that may get fixed by mfr even if you are past 60K. Good luck
Old Apr 30, 2020 | 08:31 AM
Mr.Santos's Avatar
well i actually took it to the dealer @40k for CVT drain and fill and they didn't say anything about my trans. so is it safe to say that the trans is still good? if they didn't tell me anything was wrong when they finished the job.
Old Apr 30, 2020 | 08:51 AM
kasdepwel's Avatar
I don’t know. I had a very slight judder that I complained about. They did a software update and with the update the code came.
Old Apr 30, 2020 | 09:24 AM
Mr.Santos's Avatar
gotcha..ok well glad you posted this, that way i can look back just in case my car starts juddering. appreciate the info/feedback
Old Apr 30, 2020 | 01:42 PM
240tomax's Avatar
What exactly is juddering?
Old May 14, 2020 | 12:26 PM
Mr.Santos's Avatar
you being in ***? or you really want to know? if so here you are sir. jud·der
/ˈjədər/
verb
gerund or present participle: juddering
  1. (especially of something mechanical) shake and vibrate rapidly and with force.
    "the steering wheel juddered in his hand"
Old Mar 4, 2022 | 07:17 AM
2016_maxima_sr's Avatar
I’m running iOS
im running iOS and RepairSol2 with a 50 dollar scanner and have access to transmission codes and everything else actually really happy with the scanner for my screenshots I stopped mid-scan that’s why there’s so much red
Scannable systems pt 1
Scannable systems pt 2
My current trans code
Special functions feature
Old Aug 22, 2025 | 12:54 PM
Enzo's Avatar
My 2016 Nissan Maxima SV, 101k miles. Bought it at 69k miles. Oil change done every 3-5k miles. Transmission svc done at 69k and 100k. Only drive about 7500k miles a year. No check engine lights on.
So the 2 times when my car starts giving me problems most often is when.. I’m either coming to a sudden stop or deceleration.. or while parking or leaving a parking stall, when I’m reversing my car and about to slow down to shift into neutral and than drive.
That’s when my car will sometimes kick, and the rpms drop than go back up. Than as I’m driving my acceleration is super halted, like I’m driving a Sentra with an acceleration problem as opposed to a 300hp car.
I suspect that means my car is in limp mode, but I’m still eventually able to get up to 5000 rpm and 80mph up the hill, while at half throttle, and my ac does still work and doesn’t shut off.. so than maybe it’s not limp mode.
The problem is at intersections, accelerating onto the main highway, and going from 20-40 it’s super hard, almost like I’m in 3rd gear the whole time, (which makes me feel like it’s in limp mode)
Only code showing is p17f1 CVT judder. However I feel no judder when I’m driving, only sometimes when revving slowly to show someone.. p17f1- Inspect CVT, check valve body.
The trans tech shop did that, found some shavings, drained/replaced fluid, replaced both filters, reprogrammed software. They said there was a dent in my transmission pan that was making it press up against a filter causing it to have insufficient flow of fluid. They supposedly fixed that.
Note, I have 101k miles, muffler delete, I have a K&N intake I haven’t cleaned in 4 years, the battery, alternator tested 100%. Im thinking things like dirty MAF, clogged cat, fuel injectors or filters, fuel pump, maybe even spark plugs, oxygen sensors, Idle air control valve, variable valve timing solenoid, throttle position sensor, cam or crankshaft sensor..
BUT. I don’t know, because only that one code shows on the autozone scanner. Maybe a better one will show other stuff, but everything i mentioned I see on other people’s report when I run diagnostics on their vehicle.
Some days my car doesn’t do it at all, some days it does it multiple times. If I turn the car off for anywhere from 20-60 seconds it starts right up with no problem and makes it run normal again, sometimes only until my next major deceleration, or most times I can get all the way home or to work with no problems. I usually only drive my car for 7-8 miles at a time to and from work.. 16 miles weekday mornings before work, sometimes my car does it sometimes it doesn’t.
It’s been doing this since June 22, since summer. Sometimes I feel it was to do with the hot weather or temperature, but when I work closing shift at night and reverse my car after work sometimes it doesn’t it, also in the morning where I live it’s cold, sometimes it does it as well.. my car doesn’t not have a heat shield anymore, it was too much to replace. My AC being on seems to help it NOT do it as much or often which is weird. Idk, any ideas on where to start?
I want to sell my car before it gets worse, but I don’t want to sell it if it’s something I can fix fairly cheap and easy.. however I don’t have money to go off and buy everything on a check list of sensors either.
booda226
Dec 9, 2015 05:23 PM
Max_Out
Dec 14, 2006 08:39 AM
Bluebird
Aug 24, 2004 03:14 PM
infinitiblast
May 15, 2004 08:45 AM
