wheel fitment
Old Dec 12, 2017 | 05:23 PM
240tomax's Avatar
wheel fitment
About to pull the trigger on a 2017 SL. I have 2006 Maxima OEM 18 inch wheels I have mounted with winter tires that I am currently running on my 2013 Maxima, that I want on the 2017 for winter. The bolt pattern, thread size and centre bore are all identical between the 2006, 2013 and 2017 (the offset is slightly different). How can I find out if the calipers will get in the way of installation on the 2017?
Old Dec 12, 2017 | 09:06 PM
compyelc4's Avatar
Once you purchase the '17 just remove one wheel and carefully install the 18" wheel. You should be able to feel your way through that to tell if the 18's will clear the calipers and anything else.
Old Dec 14, 2017 | 08:23 AM
240tomax's Avatar
I phoned a dealership and was told the calipers for 2013 and 2017 Maxima's are the same part number number. So I am assuming if the wheels fit the 2013, they will fit the 2017......is this thinking flawed?
Old Dec 14, 2017 | 08:55 AM
BlueSR's Avatar
Very much that is confirming it will fit. Honestly, stock wheels usually very conservative in spokes design to clear stock brake calipers with ease. Only the 4-pistons big brake kit may cause problem with brake clearance.
Old Dec 14, 2017 | 11:57 AM
CallMeThatOneGuy's Avatar
They'll fit
UCSDMAX
Jun 30, 2001 02:56 AM
MILLENIUM MAX
Feb 20, 2001 06:17 PM
MILLENIUM MAX
Feb 20, 2001 02:14 AM
MAXSD24
Dec 3, 2000 06:22 PM
