Has nissan changed anything to fix their rust problems?
Old Jan 21, 2018 | 07:24 PM
itdood's Avatar
Hi all,
any info available on whether Nissan has addressed their notorious rust problems in the current generations of Maximas?
Thanks for any info!
Old Jan 21, 2018 | 07:58 PM
FattiesGoneWild's Avatar
Car has not been out long enough to know yet.
Old Jan 21, 2018 | 08:35 PM
04BlackMaxx's Avatar
My 04 started rusting bubbles within 5 years and I was told since it wasn't "perforated" aka rusted clean through like a piece of $hit junkyard car, they wont do anything.
I'd never by another Nissan. My subsequent GM and Land Rover of all if you could believe has proven to be a far, far better and more reliable trouble free experience.
Old Jan 21, 2018 | 09:40 PM
whit's Avatar
I have a 09 I bought new and not a single rust issue. I Take care of my cars and wax n wax regularly
Just bought a 2017 new so don't expect any issues there.
Old Jan 21, 2018 | 10:08 PM
punkfs's Avatar
I have rust in the engine bay along all the welds had to sand it and repaint it, haven't looked under the car yet, i live on the ocean so everything rusts anyways
Old Jan 21, 2018 | 10:15 PM
compyelc4's Avatar
Had an '07 Altima SL for 10 yrs and 149,000 miles right here in the rust belt (Ohio). Never a problem with rust. I own a lift and even the underside was amazingly clean. Neighbor bought it. Had it for 2 years and another 10,000 miles. Looks as good as when I had it.
Old Jan 22, 2018 | 06:12 AM
sschumer's Avatar
I have an '05 Maxima with about 173,000 miles on it and have never had a rust problem. And I live in the Northeast.
Old Jan 22, 2018 | 09:26 AM
itdood's Avatar
Thanks for all the feedback. Was wondering if there's any info on if they started to e-coat hidden steel, or dip the unibody?
Old Jan 22, 2018 | 02:56 PM
compyelc4's Avatar
Yea, the '04 was junk. Rusted out floorboards under driver's feet. If you removed the carpet you could watch the road whiz by. Also, a few years in there '04-'06 I think, had problems with scored cylinders. Seemed the catalytic converter, just downstream of the exhaust outlet from the engine, would crumble and get sucked back into the exhaust valves somehow. Nissan paid for a lot of engines with that problem. As stated earlier, my '07SL was probably the best car I'd ever owned up to that point. No rust, no oil leaks, no oil burning and she could go 10K miles between synthetic oil changes with not a drop in oil level. Nissan's for me all the way now!
Old Jan 22, 2018 | 11:38 PM
lightonthehill's Avatar
I guess I have been very lucky. I have owned nothing but Maximas since fall of 1964, and I have never had a rust problem. Quite a few '04 Maximas had a rust problem on the front floorboards, because a glitch in the assembly process pinched one of the two drain tubes carrying water from the sunroof to the ground, resulting in water getting under the front mats, and it was almost impossible to get all the moisture out, so rust resulted. I caught my leak very quickly, used a flexible rod through the sunroof drain to find the point of blockage, and had it fixed. But no hint of rust anywhere on my '09 or '16.
Old Jan 23, 2018 | 03:35 AM
wild willy's Avatar
If you buy a Nissan, I highly recommend spraying the undercarriage and wheel wells with a rubberized undercoating. I had an 02 SE and did this when new, most other peoples feet were going through the floors.....Nissan metal is garbage. I did my 2012 as well, even took out the wool sweaters Nissan puts in the rear wheel wells and sprayed the bare wells. It makes a difference and cuts the road noise a bit.
MONTE 01&97 SE
Sep 21, 2003 05:45 PM
PhaZe
Mar 19, 2003 02:09 PM
Redmax
Jul 8, 2001 04:17 PM
max95q
Nov 5, 2000 08:27 AM
