Rubbing Issue on Eibach?
Old Mar 19, 2018 | 02:50 PM
ragulto's Avatar
Hello fellow Maxima enthusiast.
I have a 2016 Maxima Sr and just recently changed my tire from the stock 245/40/19 to a 255/40/19 on stock Sr wheels. I like some meaty tires . I am ready to purchase the Eibach Prokit lowering springs
My question is: will I have an issue of rubbing due to the tire specs that I have? I do am planning to change my rims to a 19x9.5 by the end of the year and use the same tires that i have now.
Your responds are much appreciated.
Old Mar 28, 2018 | 08:40 PM
BlakMaxiJoey's Avatar
a bit of rubbing, i have. fronts.
oem size tires, eibach springs, with camber kit.
Old Mar 29, 2018 | 02:42 PM
Gizmomax's Avatar
Really you’re rubbing on OEM specs? That’s not supposed to happen with the pro kit
Old Mar 29, 2018 | 08:44 PM
Crisisx1's Avatar
ahh.. don't tell me that. Mine are waiting to be installed with 19" sr wheels. You really are rubbing? Stock OEM tire size too? Or are you using spacers?
also, what is the ride height difference between the sr trim suspension and eibach? Can you post a pic? Thanks
Hmm..
Old Mar 30, 2018 | 07:37 AM
Hmm..
to clarify things, it does not rub all the time, nor on the outside of the fenders.
it only rubs on a u-turn, which is why it rubs on the rear side of the fender cover.
ride height wise, 1.5” to 2” (maybe). the dealer told me it went down 4” the first time they saw one dropped. talked to me as if i don’t know why it is that way. that made me laugh.
forgot to mention, replaced both lower control arms 60k after pro kit. the ball joint boot for the knuckle ripped. i did not have the camber kit for the first 10k miles.
Old Mar 30, 2018 | 07:52 AM
better view of my dirty car.. as requested.
disclaimer:
this is the set that was first offered for the A36.
it was also for the altima.
there is now a specific set for our cars.
so the rear dropped a bit more.
Old Mar 30, 2018 | 08:54 AM
ragulto's Avatar
Thanks for the feedback guys. I did installed mine 1 week ago. I used the Eibach Pro Kit part # 63115.140 from the Eibach website. The drop in the front is 1.5", rear is 1.0". so far, I am not rubbing even in u turns. Stock SR rims, tire size is 255/40/19. The drop in the front is perfect for my taste. The rear is a little higher than I thought. But hopefully, when is settled, it will lower a bit more that what it is now.
Old Mar 30, 2018 | 08:38 PM
seriously, though, i have no idea why it does.
the driver side is about 2”x2” patch.
the dark vertical is the rubbing spot.
i am guessing because the plastic flops a little bit.. but i really don’t know.
Old Mar 31, 2018 | 07:12 PM
Crisisx1's Avatar
can you post side pics of it please. Any spacers?
Old Apr 3, 2018 | 02:02 PM
ragulto's Avatar
Here you go!
Old Apr 3, 2018 | 04:32 PM
Gizmomax's Avatar
I’m about to do the same.
Explain in the ride in detail lol. Especially vs stock.
And did you do camber bolts?
Old Apr 3, 2018 | 06:42 PM
ragulto's Avatar
it rides like a stock SR suspension. Not bouncy at all compated to other cars.
and No, did not do any camber bolts.
Old Apr 4, 2018 | 02:23 AM
Gizmomax's Avatar
Ok cool thanks.
Sorry I’m gonna bother you a little more if you don’t mind.
What about scraping. And you’re alignment was fine after?
Old Apr 4, 2018 | 07:50 AM
Crisisx1's Avatar
Here you go!
love the look. Thanks. Can't wait to get my eibachs installed. They've been sitting in the closet for about 2 weeks now. Waiting to buy and move into the new house first.
Old Apr 4, 2018 | 08:42 AM
ragulto's Avatar
So far, I have not scrape yet doing u turns. But deep dip on parking lots, I scrape a little bit as long as you angle it correctly you should be fine.
I had an alignment right after I lowered the car.
Old Apr 4, 2018 | 08:43 AM
ragulto's Avatar
Thanks Crisisx1. You'e never regret it once you installed it.
Old Apr 4, 2018 | 08:52 AM
Malef31's Avatar
Ragulto sent you pm, but in case you didn't get it, did you have fenders rolled, or have spacers?
Old Apr 4, 2018 | 10:04 AM
ragulto's Avatar
Got your pm. Replied.
No fender rolling, no spacers. Just the ole' lowering springs and alignment.
Old Apr 4, 2018 | 08:00 PM
nice look, ragulto!
Old Apr 5, 2018 | 08:41 AM
ragulto's Avatar
Thanks you BlakMaxiJoey.
Old Apr 5, 2018 | 09:20 AM
Crisisx1's Avatar
I was considering 15mm spacers for a flush look but I think it would rub more
Old Apr 6, 2018 | 06:15 AM
robtroxel's Avatar
Help me understand why you did this to your car? The look is great but then my stock Max also looks good without the chance of being a "driveway dragger" Hard to think the handling and suspension geometry has been positively affected.
Old Apr 6, 2018 | 06:53 PM
Gizmomax's Avatar
When you drop a car (especially with stiffer springs) it dramatically improves the handling over any factory springs. It feels like a total transformed car. That along with the looks (which are 1000 times worth it compared to having that open space between the top of the tires and the fender) makes it well worth the risk of a little scraping and/or having to take a few extra seconds to avoid that scraping.
and dropping it only 1-1.5 inche (s) it barely affects anything with the alignment or the “geometry”. Now if you get to 2” or more then that’s when you have to compensate with a lot of alignment changes.
Phew...I think that more than explains it lol
Old Apr 7, 2018 | 12:41 AM
the subtle negative camber on the rear works great with cornering hard, too.
Old Apr 7, 2018 | 06:56 AM
robtroxel's Avatar
Thanks, I appreciate your comments and thorough explaination. Most of us probably don't drive that "enthusiastically" to see the benefits you describe. In the midwest we have a hard enough time keeping the stock Maxima from scrapping on driveways and acumulated snow build up in the wheel (not rim) wells.
Old Apr 7, 2018 | 07:14 AM
Gizmomax's Avatar
I’ve had many cars dropped (some on coils adjusted very low) and driven all over the states and overseas with dropped cars. You’d be amazed at what you can get away with with a mild drop like this. And even if you don’t drive it hard you’d love the difference even with every day modest driving. If you’re on a forum you’re already enough of an enthusiast that you’d love it.
RayRey21
23
Aug 20, 2007 02:12 PM
maxim82
Tires and Wheels
Oct 28, 2006 12:31 PM
devilz05
May 19, 2006 09:22 PM
Kruppa
Sep 5, 2005 06:22 PM
