Thinking about retrofitting my headlights
Old Jun 16, 2018 | 04:50 PM
CNTRT's Avatar
Back when I had my 2006 Honda Accord EXL V6 (loved that car), I baked the headlights in the oven, took them apart, and installed HID projectors in the OEM halogen reflectors.
there is a kit that TheRetrofitSource offers for the 7th and 8th gen Max, in which you take the headlights apart, unscrew the OEM halogen projector, and screw in these HID bi-xenon projectors...
I think im going to undertake this project. Just wanted to let you all know this product is out there (and no I don't work for either of these companies... Just wanted to give you guys a more legit and functional option than putting LED or HID bulbs in your halogen projectors)
https://www.theretrofitsource.com/morimoto-retro-quik-altima-maxima.html?utm_source=google_shopping&gclid=EAIaI QobChMI25ygnrvY2wIVxLXACh3zVQNlEAQYAiABEgLAw_D_BwE
Old Jun 16, 2018 | 09:20 PM
jommbi's Avatar
I saw this on retrofitsource as well and was seriously considering giving it a go. Looks like its about $350 all in.
If you do decide to go forward, please consider doing a write up. I've never baked headlights and would be very interested in how it goes with the 8th gen.
Old Jun 17, 2018 | 09:21 AM
CNTRT's Avatar
Absolutely! Will do...
Old Jul 9, 2018 | 11:03 AM
Jessica Adkins's Avatar
Baking Headlights
I have an 8th gen and we just did the baking of the headlights. My headlights did not fit in our oven so we ended up leaving the door open (stupid, I know) and melted the headlights. After ordering another set, we used a heat gun (at 500 degrees or something) and ended up doing it that way. A lot less expensive if you tell me. Butyl is so easy to take apart and can be resealed easily using what was already on there! Good luck and hope this helps save someone from having to go through what we did.
Old Jul 9, 2018 | 11:11 AM
CNTRT's Avatar
damn, sorry to hear about your lights melting! That sucks.
just out of curiouosity, what made you order another set of halogen headlights instead of just getting the LED ones at that point?
Old Jul 9, 2018 | 11:14 AM
I actually already have the upgraded headlights - I didn't bake to change the projector. I purchased Switchback DRL boards and starry eye halos, then ended up smoking all of the lenses. I'll jump on my phone and upload a photo of them. I'm still waiting on my second headlight to come in to transfer the lens over but all in all it was a learning experience and still I feel worth the purchase!
Old Jul 9, 2018 | 11:17 AM
My headlight upgrades
Old Jul 9, 2018 | 01:01 PM
CNTRT's Avatar
wow very nice!
how badly melted are your original headlights? Is it just the lenses or is the whole housing warped? I wouldn't mind snagging them off you and swapping my lenses onto them if it's just the lenses. I'd upgrade to LED in a heartbeat to save money on the full retrofit
Old Jul 9, 2018 | 01:30 PM
wow very nice!
My originals was just the melted lens. My bf used that housing for the install and just found some 'for parts' headlights on ebay that had a lens in decent condition.
Unfortunately the housing from the 'for parts' headlight was halogen. I will say though that the housing for the halogen headlights is a lot lesser quality. My headlight housing was made tougher if that makes sense. I had actual chrome where the halogen had plastic. So with that being said, be super careful prying those apart with a heat gun because those inner pieces are pretty fragile.
Old Jul 9, 2018 | 06:43 PM
robtroxel's Avatar
Jessica,
Great write up. Lights looks like they were always there!
Old Jul 30, 2018 | 05:04 PM
maxima2017's Avatar
7th gen projector with 8th gen headlight retrofit
Do you think the HID projectors from 7th gen Maxima will fit the 8th gen? They look like these-
Old Jul 30, 2018 | 05:07 PM
CNTRT's Avatar
They should yeah, although I'm not entirely sure. I assume its the same OEM manufacturer
Old Jul 30, 2018 | 05:10 PM
maxima2017's Avatar
Great! That might be a cheaper and better option as they are OEM. Used ones are pretty inexpensive.
Old Jul 30, 2018 | 05:17 PM
maxima2017's Avatar
LED in projector
You think I could use LED instead of HID in the projectors? Or the projectors work best with HID?
Old Jul 30, 2018 | 05:42 PM
NisCal17's Avatar
LED works fine. Much better than Halogens. Plus it’s not that expensive.
Old Jul 30, 2018 | 05:47 PM
CNTRT's Avatar
No. Only use what they were designed for... Halogens work best in Halogen projectors, LEDs work best in LED projectors, and HIDs work best in HID projectors...
The allure of LEDs is because they're new... But in my opinion, I'd rather a proper HID setup over a proper LED setup. HIDs still have higher intensity, and reach farther down the road.
Old Jul 30, 2018 | 05:50 PM
CNTRT's Avatar
The optics are not identical, therefore, LEDs in halogen projectors provide more light directly in front of the car, and less light far in the distance... Looks cool on the street, and gives you the illusion that its brighter... But in fact, its the opposite of being better for your distance vision, which is counterproductive when you're upgrading lights. Its worse than the stock halogens in fact, as far as visibility goes. You want more distance light, and less foreground light when its pitch black and you need to see ahead of you.
Old Jul 30, 2018 | 06:21 PM
maxima2017's Avatar
Word. Thanks for your input and clearing that up. I think I'm going to pick up these HID projectors from 7th Gen, bake open the headlight and retrofit them in the 8th gen headlight. I'll buy some quality HID bulbs and ballasts and hope they compare to the 8th gen Platinum headlights. Looking to go for a look as stock as possible. Will keep you guys updated.
EDIT- So the 7th gen is a DS2 projector and the 8th gen uses an H11 bulb. Would the connectors be different? I'll have to connect the ballasts to my factory connector and then connect DS2 to the ballasts.
Old Jul 30, 2018 | 06:33 PM
CNTRT's Avatar
No problem at all. I spent a lot of time on HID planet learning about optics and such, before retrofitting my old Honda, so that's the reason I know this stuff...
But yes, there are harnesses that connect your H11 plugs to D2S... Go to theretrofitsource.com and search their products. That site is all about retrofitting equipment! Go to HIDplanet.com also, to see the kinds of retrofits other people have done.
PS. You ALWAYS want to use a headlight harness that goes to the battery when you do HIDs. Factory wiring straight to an HID ballast can be too much strain on the factory wiring... But good thing is, the harness is just plug and play. Add 1 minute more to your workload.
ATmax99gle
Nov 28, 2007 05:39 PM
BLAKZIMA
42
Nov 16, 2005 09:37 AM
cscm094
Dec 12, 2002 09:50 PM
