Maxima Pop Clunk Noise
I have a 2017 with only 12k and have a clunking noise coming from the front left. It.Is really noticeable first think in the morning after I start to back up slowly and then apply the brake. Sounds like a bad ball joint or something. Started making the noise about a month ago. The car is at the dealer now for past 2 days. They say that they hear the clunk, but can't find what is causing it. Now they are going to change the front left axle to see if that fixes it. They are just guessing now. Dealer told me that if the axle doesn't fix the problem they are going to put it down as a "normal noise" I wont accept that as an answer for this clunking. Something is definitely wrong/broken. Might have to go up the chain of command on this one.
Graham
Graham
Graham
Graham
Ah the old famous tear your car apart guessing the problem and not actually solving it. Only to get paid for warranty work. Screw that dealership man and try somewhere else. And just so you know how this works. They are marking it as normal once the repair is made even if it does not fix it. Reason being if you say the problem is still there. They eat the cost on the previous warranty work having to reimburse Nissan since they misdiagnosed the issue.
Folks, there is a service bulletin on this issue and the dealer will work with you to resolve the problem. I have high hopes that the replacement of the shocks and shock mounts will resolve the problem because aharper posted that doing this for her vehicle solved the problem. Personally, I wouldn't look at the panels, wherever they are, being the problem. You'll have to show the dealer where that fix should be applied, and if you're trying to do that without knowledge or pictures of where those panels are precisely, then the dealer can't know where to apply the fix.
Dealers can't know what to fix if they haven't had vehicles coming in more regularly with this problem. Evidentally, there has been enough chatter about it nationally to put out a service bulletin on it, though. But a service bulletin is not a recall. A recall is a precise known issue and a precise know fix. I asked my Nissan dealer how many others have come in with this issue. He said I was the first... SINCE THE NEW MAXIMA CAME OUT!! So, you see, they can't know the fix until you've worked with them and helped them help you. There may very well be Nissan dealers throughout the US that want to scam you and work on your car when there is no reason to work on it, but I can't qualify or quantify that statement. I know my Nissan dealer in the area I live in. I know the owner's reputation in his dealer group throughout the three cities he has established his franchises. He has an impeccable reputation.
If you feel you aren't being listened to well enough where you are getting serviced, then drive the extra miles, if it is nominal enough, and find a dealer that will serve you properly.
YMMV
I've had this problem - or some similar kind of rear clunking problem - for over a year on my 2016 Maxima. I've had it in the dealership twice and I still have the problem. The first time they did nothing. The second time they replaced both stabilizer connecting rods / bushings. The sound got somewhat better but didn't go away completely. Now it's back as bad as ever and I'm out of warranty. When I get time I'm going to call in again, but I really don't want to pay to have them keep trying stuff. Will another attempt at fixing it be paid by Nissan now that it's out of warranty?
I also have rattling from the sunroof area and/or the rear which the dealer said they can't fix. As much as I like some aspects of the car, I am very disappointed in these noises. I paid a lot of money for a car that sounds like a 10 year old junker inside most of the time.
Clunking Noise Fixed!
On AHARPER's recommendation from this thread, I had my mechanic install new rear shock mounts and I just got the car back today. I'm happy to report that my 2016 Maxima SL is now CLUNK FREE!!! On my ride home I tested it as best as I could and not even a whisper from the back end. I just purchased the car in January and once it turned cold the clunking noise became very pronounced. We've had a brutally cold February and as the temperature got colder the noise got worse. When I took the car in originally, my mechanic could not get the parts that day and said they would be $30 a piece, but I recalled seeing the shock mounts on Amazon for about half that price. So I ordered them on Amazon (
) and then took it in today after they were shipped to me. After the install was done, they told me that the original bushings were actually installed incorrectly and the washer was in the wrong place causing the the metal on metal cracking noise. Probably an oversight in the original assembly at the factory.
Anyway, the annoying noise is gone and I am thrilled. I will report back in 100 or so miles to confirm the issue is resolved.
Going to take mine in and have them do this now that spring is here. They were offering to replace the rear shocks. That is the last resort I think and I'm more likely to get them to do this without a fuss than the entire shocks.
On AHARPER's recommendation from this thread, I had my mechanic install new rear shock mounts and I just got the car back today. I'm happy to report that my 2016 Maxima SL is now CLUNK FREE!!! On my ride home I tested it as best as I could and not even a whisper from the back end. I just purchased the car in January and once it turned cold the clunking noise became very pronounced. We've had a brutally cold February and as the temperature got colder the noise got worse. When I took the car in originally, my mechanic could not get the parts that day and said they would be $30 a piece, but I recalled seeing the shock mounts on Amazon for about half that price. So I ordered them on Amazon (product link) and then took it in today after they were shipped to me. After the install was done, they told me that the original bushings were actually installed incorrectly and the washer was in the wrong place causing the the metal on metal cracking noise. Probably an oversight in the original assembly at the factory.
Just confirming that the issue is with the shock mounts which I had replaced on March 12th. After 3 days of driving my 2016 Maxima over pothole filled roads I have not heard the clanking sound whatsoever.
Just had this done to my 17 and I can hopefully concur with this problem and the fix. Sorry to dig this old thread up but I hope it saves people from wasting time having Nissan hunt and peck in the wrong place. In fact, driving it about 12 miles after the fix, not even railroad tracks induced the clunk. The rear of the car feels firmer yet calmer. Yay! Thanks rspeigs.
I have a 2016 and hear the noise, agree it's much worse when cold. Every single morning when leaving for work, I hear it, after driving a while the noise seems to go away or quiet down quite a bit at least. I went to the dealer a few weeks ago actually, they put the car on the lift and checked sway bar end links, bushings, wheel bearings, tie rods, ball joints, etc. Said all looks fine.
To me, it sounds like the clunk is coming from the passenger front area.
After some additional experimentation, mine is definitely coming from the front passenger side. I can confirm that when the car is cold, it is way worse. I drove slow over bumps when the car was cold and it "clunks" when the front hits a bump, not the rear. I also wrapped towels all around the bars in the trunk to eliminate that possibility.
I'm of the mind that Nissan uses garbage strut/shock mounts. There are the same Monroe kits for the struts that I put on the rear shocks. You may have a defective strut though, if it's not the mount then it's the strut, it shouldn't be bad so soon for a car this age. Good luck with warranty begging at your Nissan dealer. My dealer knocked a bunch off the labor, maybe half, because this wasn't a TSB or anything that I had done, it was my choice. Since it worked they were really gracious about it and took some responsibility. I still have 20K on warranty.
If you can determine it's not the strut itself, I would try these: http://www.monroe.com/en-US/e-catalog/902022
Bumping this thread again...now that it is getting cold in MN I can hear the noise pretty much throughout my entire drive. I brought it to a different Nissan dealer this time and told them about the front passenger side clunk. They said it would be $70 for diagnostic, if it is the strut mount it would be another $70 for the part, $250-300 for labor and $120 for an alignment! To fix this clunk it would be over $500! I told them no way, this is a 2016! This is my first Nissan, had a 98 LS400 prior to this and only issue was a starter the entire time I had it. I'm temped to just buy a new strut assembly from Rock Auto but I have never put one in before. The noise is so obnoxious.
Just resolve in your mind that Nissan builds junk these days, the good old solid Maxima is history, the stuff coming out of Smyrna is cheap. The last good Maxima I could depend on was made in Oppama Japan. I'm dumping my Maxima first thing this spring. Nothing but a cash cow for the service dept at Nissan. Garbage.
2017 Sr and I just started hearing the loud clunk noise from the rear, however mine sometimes feels like it's coming from the outside rear. Only happens when going over bumps or turning over uneven surfaces. It's a lot louder in the morning before the car is heated up.
Does tsb ntb 17-040 address this?
Can confirm that changing out the rear shock bushings will alleviate the popping noise. Got it done to the right rear shock last year and the left rear shock about a month ago after the noise started on that side. No pops from either side since we had the work done. I’ll update with the RO info if I can find it.
Thanks if you are able to hunt this down.
I will call the dealership and see if they can send me a copy. I can’t find the original. I know they ordered a shock for it, but I don’t know if they installed the shock or just changed the bushing. I’ll keep you posted.
Had that very thing with my '07 Altima, if it is the trunk lid torsion bars you are referring to.
[QUOTE=NisCal17;9187947]
I think I found the source of clunky noise. Fold your rear seat and try to move the this plastic piece. I stuffed some bubble wrap founded in the trunk( amazon package) under this plastic cover to see if it will illuminate the clucking noise and it did. I will apply much more sophisticated material later on when I’ll have time.
[/Thanks for indicating this area. I ended up applying cell foam tape to the edge and back side of that plastic cover as well as under the rear deck edge (crazy rattling sounds when tapped lightly) it has completely solved my issue
[QUOTE=2000G6;9214565]
Thanks for the report. A picture would really help us on what you did. Thanks!
Looking at the RO it looks like they only changed out the bushings. I haven’t been able to reach the SA to confirm but I’m going to call again tomorrow. I personally don’t think they replaced the entire shock. But will advise.
The only thing she could advise was what was on the R/O which was they changed out the bushings. I’m going to email the Service Manager Monday to find out if there was anything more extensive. He’s hard to catch as to why I haven’t reached out to him as of yet. Will advise.
I do have the service invoice where they tore out essentially the entire back half of the interior. It’s not the rear deck. It’s the rear shocks/bushings or both. They did the right rear last year and the left this year. Same noise. Same solution.
